I’d like to use the fuel the event provides. Any reason why Gatorade Endurance and gels/Cliff blocks shouldn’t be my fuel of choice? And, for the record, please don’t give me a summary of your own fueling choices. I don’t care. I want to know what you think about my fueling choices.
I think you should take on some protein, too. I don’t think the blocs have any.
Say hello to Patrick Chewing:
Your fuel will work. I know you don’t want a summary, but I survived on GE & gels for IMLP a couple years ago. Well, that and some coke on the second half of the run. All I carried were gel flasks on the bike–using aid stations for the GE. No stopping at special needs required.
Thanks!
One clarification - I am happy to receive personal experience testimonials from people who used GE and gels or Cliff blocks for a race. But otherwise I don’t want the slowtwitch tradition - 45 posts by people talking about how they really like Heed, Perpetuem, etc.
Should not be your fuel of choice as you will need to drink gallons of it to get the calories required to sustain your effort. I think you get about 160 per bottle. That’s going to be a lot of liquid
Agreed that GE can’t provide me all the calories I need. I’ll drink GE in lieu of water. 20 ounces per hour would be 125 calories per hour (I think it is 125 calories per 20 ounces). I can get 200-250 calories per hour from Cliff blocks and gels.
If you like gels and your stomach can handle them then that would work. I have a sensitive belly so not for me, I do like the supplemnting with blocks as they tatse okay and slowly dissolve under your tongue
They’ll work just fine.
8oz is 50 calories. 1 bottle is 21 oz which is about 150 calories? 1 bottle gatorade and 1 gel per hour gives you 250 calories.
Used GE and gels (gu) for IMoo 07 (also ate powebar, fig newtons, banana, and drank flat coke). Also took sodium pills. Plan to use that again this year.
GE worked absolutely great for me. If that’s what you train with, should work fine for you.
Will work, as he SHOULD be drinking ~40oz/hour (almost everyone underdrinks on IM, esp on the bike). Do a hard bike for an hour. weigh yourself before and after, and take into account what you ate and drank. on almost everyone it is 35-45 oz/hour. Almsot no one is drinking enough during IM.
I used GE and Pwrbar gels at IM Brazil last year (my first). Worked just fine, if you can stand it. (I did pop a Nuun into every other bottle of GE on the bike though, and for about 2 hrs I just couldn’t stand another gel, so I ate some bananas.) 2X Caffeine Tangerine Pwrbar gel will always hold a special place in my heart after that race.
Not wnating to hijack the guys thread, I did the test and was around 35 which means I drink 2 bottles every 1.5 hours and get the rest by taking another bottle of water from and aid stattion. Drinking more than 40 is pretty hard on the belly and leaves me feeling bloated.
I also aim for 400-500 calories per hour so the GE and gus won’t work for me as find my stomach does not like GU.
Used nothing but GE and Cliff Shot Bloks on the bike for both IMLP and IMAZ. I sweat heavily and training showed me I could handle more than 1 liter per hour, so I set my countdown timer to 12 minutes and had 8 ounces every time it went off. That gave almost 1.2 liters of fluid per hour and 250 calories. A couple of Shot Bloks brought the total to just over 300 calories while keeping the carbohydrate concentration still under 8% (6-8% concentration is optimal for absorption and emptying).
Big benefits as I saw them:
- Never had to worry about special needs bag (although I did have one with a tube and spare CO2 in case I had to use the ones I was carrying on lap 1)
- Left transition with NO bottles on my bike for both races. My stomach needs to settle a bit before taking anything and the first aid station comes along right about the time I’m ready to start my nutrition plan.
- Minimum number of bottle cages hanging off your bike means you’re more aero. At IMAZ, I raced with a single cage on the downtube. The schedule I had, I only needed new bottle every 36 minutes (aid station 1, get bottle and drink 1/3 of bottle, 12 minutes later drink again, 12 minutes later drink last 1/3 of bottle, don’t need another bottle for 12 more minutes after that). Want to be extra safe? Grab a bottle at the front end of the aid station and rack it. Grab another bottle at the back end, drink, and chuck it. Plus, you can always swig down some water if you need to.
- Minimum number of bottle cages means minimal weight on your bike at all times. At a race like IMLP, you’ll probably notice. Imagine a fairly typical IM setup: downtube bottle cage and aero bottle between the bars. If I used that, I would have been carrying an extra 4 pounds up that first hill at IMLP. At all times, I’d probably have at least 2 extra pounds on the bike.
You definitely need to do some long training rides at near race intensity followed by a 3-4 mile run to see if your stomach can handle it. If it can though, keep it simple.
I’m not an IM guy, so take this for what it’s worth.
I’d be worried about how much salt there is, and how that would effect you - especially if it isn’t that hot when you race.
I’d also be sure to practice using a lot of Gatorade Endurance.
Finally, don’t forget about your teeth.
-Charles
The one caveat that I would add is that those blocks can be tough to eat on the run if you don’t have a ton of liquid to chase them down with.
In terms of what GE has in it, it should work if you supplement calories. But the question I have for all of you is how on Earth are you able to keep drinking that crap for 10 hours or more? The taste is SO strong that I want to hurl after the second bottle. It’s almost impossible for me to choke down any on the run. I force it in, but chase it with a bunch of water. I hate bringing my own stuff, and would like to use GE, but the taste is just too much for me. Do you guys really drink that stuff straight up? Do you eat cotton candy and Peeps just as snacks too???
I stop drinking the GE once I get to the run. From there out it’s water, Coke, chicken broth, pretzels, cookies, etc. Pretty much whatever my body craves as I cruise through the aid station.
You will probably want something more solid at some point and you will probably want some water as well. Otherwise it should work if you train with it.
Edit: saw your line about substituting gels for water? That seems like a problem to me.
I race all my races on GU and GE. No problems. If you use GU make sure to take it with water to digest better. On the bike I go GU/water, alternating every 15 minutes or so. On the run GU one aid station, GE next, etc…
Works for me.
