I have an SRM but I assume things are similar with Quark (not sure how many SRM people run 705’s).
When I stop pedaling - the 705 freezes my power and cadence at the last value. So if I pedal at 300 watts with a cadence of 80 over a hill then coast and stop pedaling downhill. The 705 says my power is 300 and cadence is 80 until I start pedaling again. Now I know my cadence is 0 and my power is 0 at this time :). To make matters worse - the average power keeps going like the current power is 300!
When I go to “calibrate PM” - should it do anything? It shows me a number like 622 Hz - then I click on the “calibrate power meter” message with the thumb stick and it just goes back to the accessories screen. My power seems accurate but I was wondering…is there any other ways to zero the SRM?
Can it autozero somehow while I ride?
How do I find altitude info after the ride once I reset the 705 and I’m in history mode?
If I use smart recording - does it still record power every 1 second?
I’d guess that you have firmware v2.8 installed on the Garmin. You can check this way: menu - settings - system - about edge
We’ve seen similar things happen in conjunction with the CinQos after folks updated their firmware to v2.8. For CinQo users, we’re actually recommending folks go back to v2.6, combined with doing a hard reset on the unit, until Garmin releases new firmware again. (V2.7 seemed to lead to corrupted files that couldn’t get downloaded…) You should call SRM though and see what they recommend for use with their power sensors.
To reiterate, don’t use smart recording (that won’t allow you to record at power at 1 second intervals). There is plenty of memory for you to use 1 second recording all the time.
