Garmin Vectors 3 and Wahoo Bolt
I’ve done the Googling and can’t tell if Garmin Vectors 3 and Wahoo Bolt are compatible. I found some things that indicate yes and some that indicate no. However, all of these things seem to be dated.
Can anyone confirm either way?
Yes.
I’m not sure the Wahoo unit can read all of the detailed cycling dynamics like L / R balance, but it will certainly ready all of the normal power info.
Yes.
Thank you!. This is also what I thought was the case. I’m just interested in a straight power number so the Wahoo will serve me fine.
I put about 20,000 miles on that combo this year. Zero issues. I also do have the new 530 for MTB use and that does seem a little more refined and seeing the l/r balance is cool.
Simplicity the Wahoo is great. I don’t need fancy.
Refinement and bells the Garmin seems a little more pretty and better in that regard. And is supposed to have much better off road capability for single track mapping.
