size?
Mex, I don’t know the seller but heck of a deal and FYI, I was successful with old standard pods and a 6" flat file held at 45 degrees to modify in order to fit my new Cannondale w SiSL2 cranks. I mention just in case old standard size scared you away, a few passes of the file and clearance is very clear.
the measurement for my cranks (FC-9000) are 13mm and 40 mm. It’s stuck in the middle of Garmins pedal/pod sizing.
They are standard pedal size I believe 12nm 38mm wide
I thinkthe 38mm will work, but I don’t have the most experience
Thanks for the info!
Yes, it sounds it on your 9000. I needed to create clearance for 39mm wide and 15mm thick. Hopefully the seller will reveal what you want to hear and it is the large pods. If not, add $100 for ‘new standard’. Good luck sir! To add, coming from Powertap set up on a nice mavic Cosmic set which never let me down, the Vector’s are solid and I’m pleased with the change. Again, good luck.
Mex, I have no skin in the game but I will go out on a limb and state that I think you’ll be successful filing off the corner of the pods which as new don’t clear your DA9000 arms. I have no reason to meddle but this interests me only because I was so excited to succeed in saving the old standard pods, I thought I’d throw it out there. Who knows? Maybe you all want to negotiate the dollars so you can get new pods? Okay, I’ll shut up now. : )
Nope, just waiting for his paypal info. Thanks for the help though. It’s a great deal even if I have to buy the larger pods.
Mex, one more thing: you’re not going to get the crowfoot 15mm ‘socket’ with these pedals for the purpose of getting a known torque on left and right install using a torque wrench of course. Garmin included only w the ‘new standard’ and large. There is a park Tool # for it or I did see a 15mm crowfoot at Lowes in the socket department but unsure if it was narrow enough to fit pedals. It appeared to be narrow enough but that was just eyeing it.
