Garmin to Training Peaks
Read the instructions, but either they are obtuse or I am dense.
I have an Edge 705, and tried saving it to the desktop and then uploading, with no luck.
TIA
You’re not obtuse, you just need a middleman:
http://support.trainingpeaks.com/device-agent/download-device-agent.aspx
This is a program that will suck the workout out of your 705 and puke it into TP. I use it all the time with my Forerunner 305.
Good luck!
SMC
Plug in the 705 with your USB cable. A new hard drive should show up. Look for the “history” folder and find your ride. Drag it over to WKO “calendar” and another dialog should pop up. Select the right athlete and it should parse the file and add it.
Hope that helps.
EDIT silly me - I thought you meant Training Peaks WKO software and not the online tool. oops.
Sweet. Thanks for the info.
BUT now the TP Device Agent won’t recognize my Garmin.
It shows up on my desktop, it synchs with Garmin Training Center, but is not recognized by TPDA on either USB port.
Help?
