Garmin Edge 605/705 base maps
I’m thinking about purchasing an Garmin Edge so that I can expand my dull selection half a dozen different rides that I do. There are lots of nice roads and routes around where I live, but I always do a few tried and true routes as I hate printing off queue sheets and I don’t want to get lost by just going out exploring. Will the Edge 705 base maps (that I have heard are pretty poor), accept a ‘return to home’ function that I can use once I get halfway through my ride? Can it accept and show detailed Map-my-Ride routes, even if the roads usually wouldn’t show up on the base maps? Those would be the two scenarios that I would most likely be using. I don’t really want to spend another $100 on some software maps…
As far as the 705 choice, I’d eventually like to upgrade my wired Powertap to either a Cinqo or a newer Ant+ compatible wireless Powertap in the future but I believe the maps are the same as the 605.
I just moved to the UK and had only the ‘base map.’
The 705 works great for that!
It’s as easy as setting up a route on google maps(or other website) and transferring it to your unit via a GPX file.
Sounds pretty complicated if you read about it, but once you figure it out it takes literally 3 clicks of your mouse.
