Is it possible to change the data fields in triathlon mode on the 935? I can change them in other modes but can’t find the data fields setting when in triathlon. I go to triathlon settings but then it lists the activities, I go to activity 2 (bike) but no data fields…just change and remove. My wife says I’m blind so perhaps this proves it?
I don’t think you can change the data fields in “triathlon†mode. That mode grabs the data fields based on the underlying activities, i.e., outdoor swim, outdoor bike, run. So you’d need to change the data fields in the underlying activities, then those changes will be reflected in triathlon mode.
Thanks for the quick response, you are correct. It has to be done in each individual mode and then they carry over into triathlon mode. Should’ve guessed that one on my own. thanks again!
If you have different screen setup preferences for say, road riding versus cycling in a triathlon, you can copy and rename the Bike activity to Road Cycling. Triathlon would pick up the original Bike activity settings, but for day to day riding you would use the new Road Cycling activity.
You can also create a custom multisport profile - so for Xterra you could create a new multisport profile that picks up the MTB activity.
