Garmin 405 question
My Forerunner 305 finally died so I picked up a 405 today. The one thing I haven’t been able to figure out is how to set a heart rate cap for my runs. Say for example I want to set a cap of 149 and want it to beep at me when I go over. It was pretty simple on the 305 but unless I’ve missed it in the manual I can’t find how to do this.
I saw the HR workout option but that’s more something you do for each run. For example I’ve got an hour 30 in the morning so I could set the 1:30 HR workout but of course that wouldn’t work for my next run which might be 50 min.
Help.
  1. Make sure you have your HR zones set up the way you want. For example, if you just want to “cap” your HR, set up a zone with your cap as the max and something ridiculously low for your low end. Also, make sure your Alert tones are “on” (menu->settings->system->alert tones)
  2. Create a new workout in Garmin Training Center.
As the workout duration, choose "Go until I press the “lap” button on my device. Under “Selected Step’s Target” choose “Try to keep my HR in a certain zone”. Select the zone with your cap as the max.
  1. save the workout.
  2. Upload the workout to your 405.
  3. Select that workout
  4. Hit the road.
The workout will last until you hit the lap button. If you want to go 30 min today, then hit your lap button after 30 min. If you want to then go 60 min tomorrow, select the same workout for tomorrow and hit your lap button after 60 min.
