Got the 310XT Today! Seems very cool and just what I need. And it fits my wrist just fine thank you! Its light and runs easily on the wrist.
In the Running data fields, I can get total time normally, and current pace in miles (such as 8:30 pace) no problem.
The distance field reads in feet, and I cant change it to miles (like it shows in the quick start guide photo)?! Do I need to run a mile first before it converts the data from feet and begins to read in miles? Or is there another setting I cant find?
Of course its all set up in statute (not meters), and there does not appear to be a way to change the field from FT to MI. Any clues here?
Also, when in multisport mode, does each sport (as you change it) read the time for just that sport you selected, or does it read cumulatively as the day progresses? The users guide is a clear as mud on this.
Only a week to go to IMLP and I gotta figure it out!
press mode
select settings
select system
select units
smash yourself in the balls
on a more helpful note, if you hit the ‘up’ or ‘down’ arrows in multisport mode it should let you alternate between overall (or multisport) time and your run/bike/swim specific time
Its all set up correctly in statute (meaning it should read in miles). But it reads in FEET! I even tried setting it to metric, and then back to feet. No luck.
So, how do I change this field from feet to miles? The only options in settings is statute or meters (not feet, so where did this option even come from)
TT
PS: Of course, thanks for your help and anyone else who can keep me from pounding my head against the wall!
It’ll always read feet first until you pass a certain distance, then it switches to miles automatically. I’ve never paid attention to where it switches over.
Thanks very much for the help. I will take it out for a quick ride around the block to make sure it switches from ft to mi. Sounds like its working fine, I just didnt go far enough. Who Knew? Ha Ha
I also will be racing IMLP next week and had been looking into buying 310XT , but had been unable to find online shop that had in inventory for ready shipping. Can you give me info on where you were able to purchase much appreciated.
I swam in mirror lake today with it. It does record distance while swimming! So that part works! I will test it for a ride/run tomrorow. So far, once you figufre it out, it seems easy to use. More to come.
The water is really great by the way! Probalby about 68-70 degrees.
TT
I afraid to take mine swimming, lest I find out my “3km” open water swims were not really so.
Mine recorded as well, although I could swear it significantly overestimated the distance I swam as the distance and derived pace it had for me was way faster than I usually swim. I’ll try and compare with an independent data source.
Road Runner Sports has them… without the new HRM strap.
