Garmin 205 / 305 Mounted on Tri Bars
I have spoken to a few people who had a problem mounting their Forerunners using the quick release kit when tri bars are attached.
The problem arises mainly because the quick release bracket needs to go on a bar that runs from side to side. The handlebars are taken up by the tri bar which doesn’t leave anywhere.
I made a quick solution with some zip ties. One ties the cradle on and the other one uses ties as a holder for the quick release watch strap so you get two choices to use in T2.
Both methods give a cushioning effect that overcomes the issue some people have with hitting a pothole, or whatever, and causing a jolt that ejects the Garmin. Never happened to me but I have heard a couple of people mention that. Having said that they also feel really sturdy and the placement of the ties means that if one breaks the Garmin doesn’t drop to the floor.
This one uses two cable ties running across the tri bars with the velcro quick release strap attached round it. Just remove it in T2 throw it on your wrist and off you go.
http://i29.tinypic.com/2912gcy.jpg
The next version uses a similar base of 2 cable ties but then also cable ties on the quick release cradle. This means that you can swap the Garmin over to your wrist strap whenever you feel like it.
http://i27.tinypic.com/2mpbcm0.jpg
http://i25.tinypic.com/oe4io.jpg
This is a great solution for your bar set up. I have Syntace C-3 bars and a Stratos CX bar and find the Forerunner 305 sitting sideways works best.
http://i268.photobucket.com/albums/jj10/Juanmoretime/20090719_1.jpg
yep, i might even not mind it facing the wrong way but that was the problem that people were telling me, the fact that the garmin, due to the way the quick release mount works, wasn’t mountable facing the correct way.
If you want to actually see it, get a Profile UCM mount. This pic has my Edge 705 on it, but I had my FR305 there too. Works great.
http://i126.photobucket.com/albums/p85/dr_pete177/IMG_0151.jpg
