After finishing IMAZ a few weeks ago, I decided I needed a new bike…so I bought this Griffen used from a guy selling it locally. I spent all my money on the frame & now need the 'twitchers help to build it into my dream bike.
If you were building your dream bike, what would you put on this bike?
There is a neat tool over on http://weightweenies.starbike.com/ called the PBC (paper build configurator) which lets you design your bike with the parts you want and see what its total weight will be: Paper Build Configurator -beta-** Frame Trek 5500 OCLV USPS 54 cm 1246 g 1 1/8" headtube, w/ headset cups, w/ bottle cage bolts Fork Kinesis Wedge 1" 700C 536 g 238 mm steel steerer, carbon fibre aero blades Headset TOKEN EOXIS-Z (TK667CN) 1 1/8" 73 g excl. star nut (10 g), top cap (8 g) and bolt (8 g) Headset Spacer ZIPP Carbon 30 mm 12 g 1", thick high quality carbon w/ ZIPP logo Stem Weyless M-8 80 mm 7° 137 g 1 1/8", for 25.4 mm bars Handlebar Syntace C2 Clip Ultralite M 389 g clip-on aero bar Grips/Bar Tape Ritchey True Grip WCS 57 g foam Bar Ends g Seatpost Specialized Pave Advanced Composite 27.2/350 mm 260 g Saddle Selle San Marco Aspide Triathgel 205 g Seatpost Clamp CODA OEM 27.2 mm 45 g QR Brakes Shimano Ultegra BR-6500 337 g front/rear 171/166 g, also weighed 330 g g Shifters Shimano Dura-Ace SL-BS77 177.5 g bar end shifters incl. mounts, averaged (176/179) Brake Levers Shimano Dura-Ace BL-7402 240 g Aero road brake levers Front Derailleur Shimano Ultegra FD-6500 braze-on 80 g +30 g for 35 mm band adaptor Rear Derailleur Shimano UItegra RD-6500-SS 216 g short cage Bottom Bracket Shimano Ultegra BB-6500 68x109.5 mm 231 g Octalink, BSA Crank Set g Pedals Shimano PD-7800 282.5 g SPD-SL, averaged (281/284) Chain Shimano CN-HG93 108 links 273 g 9-speed Cassettes Shimano Ultegra CS-6500 11-23 9-speed 195 g w/ lockring (13 g) Skewers Tranz-X Secura Lock 96 g front/rear 46/50 g Wheels HED Stinger V50 1490 g 700C tubular, w/out skewers (add 45+55 g), claimed 580/810 g Rim Tape g Inner Tubes g g Tyres Tufo S3 Lite <215 g 700Cx21 204 g Tubular tire, averaged (200/201/205/210) Tufo S3 Lite <215 g 700Cx21 204 g Tubular tire, averaged (200/201/205/210) Cables g g Bottle Cage(s) CatEye BC-100 41 g w/out bolts (+5 g) CatEye BC-100 41 g w/out bolts (+5 g) Custom #1Profile Air Wing bullhorn bar 240 g Custom #2Rotor Cranks RS4 Ti 1230 g Custom #3Cables 150 g Custom #4 **Grease 50 g 8738 g created in 0.66299891471863 http://weightweenies.starbike.com/
