Does anyone know of an aftermarket maker of aero ISP tops for a Fuji SST 1.0? I need a zero set back post top?
I would go with fuji I think everything is special for that bike, I have the 09.
I assume you’re on the oval branded mast topper? In 2010 they came with a Ritchey Aero Stubby that had a sliding adjustment (-25mm to +5mm at least according to mine). You could ask Ritchey to see if they have any available I suppose.
You might also try a Scott dealer, as I’ve heard that the seat mast toppers for their Plasma (non premium) frames that used to have ISPs were the same shape (also made by Ritchey with the same adjustable rail).
Good to know…thnx gonna look into that.
As a follow up to this incase someone else has the same fit issue as me. Fuji says no dice on a zero setback option, and they doubt any others will fit since the shape on the 1.0 is new and pretty specific to the bike. Thnx for the thoughts folks.
