FSA sizemore delamination? anyone else have this issue?
my FSA sizemore stem is peeling for lack of a better term. a clear coat applied to the paint is chipping off leaving a matte coat visible underneath.
they are kind of giving me the run around on warranty. i am going to send it in and see what they do as i have a spare stem.
Every sizemore (more than a handfull) I’ve seen has had this - have never bothered going for warranty
Yep- same problem. Never gave it much thought.
yeah, i considered just letting it slide as its a cheap part, but i have just been annoyed with companies not being accountable for problems with their products or services recently so its going back. the fact that it happens often makes me want to send it back even more as i am sure they would fix the issue if loads of people came to them looking for new stems. though it also probably means this will happen to the replacement as well.
Clear coat chipping is a lot different than delamination. One is cosmetic, one is structural.
i suppose if you are refering to the word as a term of art, but a piece of aluminium is not going to delaminate and the dictionary definition of delaminate is “to split into laminae or thin layers” which is exactly what the clear coat did.
This doesn’t only happen to the sizemore stems, but at least in my opinion, that’s not a big deal. Paint issues are pretty common and clear coats are just asking to be chipped. Granted if it was a $100+ stem, then maybe I might be a bit irritated but I really don’t know if cosmetic issues like that should be cause for a warrantee claim. But if I did claim it, I’d refer to it as “paint chipping & peeling” versus “delamination” as you need a laminate for the latter to happen and the and this case it’s basically “paint chipping & peeling” off of the painted aluminum.
since i spend more time on my bike than the really fast people, i care how it looks, especially the part that i have to stare at.
FSA does warrant ‘workmanship’ which should include paint, but you are right, its not worth it for a $35 part. i think i am just going to try and peel all the clear coat off so at least it is uniform.
i do think it is BS that they were evasive about it and will vote with my $ next time i buy a bike.
