I recently purchased the FSA Platinum bottom bracket to go with their carbon compact cranks, is there any big difference with this bottom bracket compared to their ti version? Thanks.
I have the Ti on my tri bike and the platinum pro on my road bike, there is a weight difference, and unless they changed things the bolts that mount the crank arms are a different size, one is m14 the other m15. I believe the bearings are the same for the two higher models, with cheaper bearings in the srtaight platinum. I got a really good deal on the Ti one about a year ago, but without that deal I do not believe I would have spent the extra money. There are also rumors floating around about Ti BB spindle shearing, but mine is great after about 1500 miles. Their products seem to be high quality and come with everything you need and even extra parts with some items. On a side note if you wrench for yourself buy a crank extractor and forget about their self extractor it is not so great. The platinum pro is probably you best bang for the buck in their line.
