Fs: xterra vortex full wetsuit - $80
Men’s Size “SLO” which equates to small-long. I am about 5’9" 140 lbs. Could fit someone with 20 more pounds around the chest and midsection easily. Yeah, I’m not exactly an Oven Stuffer Roaster. Purchased new in '03. Switched suits last year - need to move this one out. Suit is in very good servicable condition. Of course, it’s used so it is not perfect. Get a new one if you want perfect. There is some minor ‘checking’ (?) of the rubber skin around the front of the armpit at the seam. I use the term ‘checking’ because the imperfections are not tears through the suit but just radial spilts to the rubber surface that radiate out from the armpit seam about 2-3cm. The seams are solid. There is no indication of tearing to the backing martarial which is like a soft canvas type stuff. Had a problem with this in the crotch too, but used some suit repair gunk to fix it - just never got around to patching the pits. Really, I’m making a bigger deal of it than it is. It’s in really good condition and will serve you well. $80 shipped to conti USA. A little more elsewhere.
Thanks.
PM sent.
