I’m trying to clean out my basement before we move. In the photo below, you’ll find well over half of your fixed-gear winter project bike - a 59cm steel Trek Elance frame/fork (with Trek decals removed), Kore seatpost, Fizik saddle, SunRace front wheel, no-name quill stem, no-name threaded headset, and old-school crank with 52-tooth ring. Add a brake, bars, chain, bottom bracket, and fixie rear wheel and you’re ready to ride. The frame has semi-horizontal dropouts, which should make setting chain tension a breeze - no eccentric bottom brackets or hubs needed.
$100 buys you the whole shebang, and I’ll split USPS shipping with you (price determined by your zip code). Paypal would probably be easiest for us both (account name - brozek@polisci.wisc.edu), but I’d also take a money order or cashier’s check.
Thanks for looking!
Jason
