For sale is a Brand New SRAM/Truvativ Pressfit 30 Ceramic Bottom Bracket. Item was opened, but NEVER installed. I did make a couple of notes on the installation diagram before I realized I had the wrong bottom bracket. Comes in original packaging with instructions, ceramic grease in syringe as well as the ceramic bearings installed in the composite sleeve. Packaged and complete just as you would get from a retailer. $150 shipped within the U.S. via USPS. Paypal preferred.
Additional info: 42x30x7mm BB30 cartridge bearings housed in a press-fit, composite sleeve assembly for use with BB30 cranksets in a “PF30” frame with a 46mm-ID shell (fits both 68mm or 73mm shell width). Press-fit 30 frame design eliminates the need for internal bearing c-clips and tension wave washers used in a traditional BB30 bottom bracket. Manufacturer: TruVativ. MFR’s Part #: 00.6415.041.010. UPC: 710845622038. Model: TruVativ PressFit 30. Weight: 78g. Spindle Interface Type: BB30. Frame Interface Type: PF30. Fits frames with 46mm BB shell ID designed specifically for this system. 30mm crank spindle compatible. Gutter seal technology to prolong bearing life. Make sure your frame matches the bottom bracket style before purchasing!
