I am selling my Specialized Transition Comp. 56cm This bike has less than 400 miles on it and has been perfectly maintained after every ride. If any one is looking for a great tri bike for a great buy this is the one for you. The bike will be sold with original wheels - Asking $850
FRAME Specialized E5 AEROTEC, fully manipulated aero tubing, compact Transition design, internal brake and derailleur guides, replacable derailleur hanger FORK Specialized FACT carbon aero Transition Speed Zertz, carbon legs, aluminum steerer HEADSET Specialized Mindset, 1 1/8" integrated threadless, sealed cartridge bearings, carbon 20mm cone with two 5mm alloy spacers STEM Specialized Pro-Set lightweight stem, 3D forged alloy, 4-bolt 31.8mm bar clamp, 4- position adjustable HANDLEBARS Specialized Zertz Transition bullhorn bars, 31.8 clamp, with Profile designs Carbon Stryke aero bars TAPE Body Geometry, cork ribbon FRONT BRAKE Shimano 105 REAR BRAKE Shimano 105 BRAKE LEVERS Tektro RX4.1 aero levers FRONT DERAILLEUR Shimano 105, 10-speed, 31.8mm clamp, bottom pull REAR DERAILLEUR Shimano Ultegra, 10-speed, short cage SHIFT LEVERS Shimano Dura-Ace 10-speed bar con shfters CASSETTE Shimano 105, 12-27t CHAIN Shimano 105, 10-speed CRANKSET Shimano 105 double crankset, Hollowtech II, 2-piece design CHAINRINGS 52x39T BOTTOM BRACKET Shimano 105 Hollowtech II PEDALS Composite-body test ride pedals RIMS Mavic Aksium FRONT HUB Mavic Aksium, 20 hole, Mavic QR REAR HUB Mavic Aksium, 24 hole, Mavic QR SPOKES Stainless 14g aero FRONT TIRE Specialized Mondo Pro, 700x21C, aramid bead, 120TPI REAR TIRE Specialized Mondo Pro, 700x21C, aramid bead, 120TPI TUBES Specialized standard presta tube, 0.9mm thickness SADDLE Body Geometry Transition Pro saddle, microfiber cover, full nose padding, cro-mo rails SEAT POST Specialized Transition carbon, aero seatpost with Speed Zertz SEAT BINDER Specialized CNC, alloy
