Selling 3 of my custom builds, too many bikes in my stable right now:
2009 S-WORKS Tarmac SL2 56cm - Sram Force and Easton Wheels
Full set of photos here: http://www.flickr.com/...s/72157629149999584/
Built with Specialized’s top of the line frameset 11r Carbon, this bike is crazy stiff and you feel total power transfer to the rear wheel - there is no flex to lose power from. Despite its stiffness, I coupled the frameset with matching Zues carbon bars and a Zues carbon stem (typically seen on high end Orbea’s) to allow it to be a bit forgiving to your arms and shoulders on any distance (noticeably comfortable on a century ride). With this setup its super light, made for sprinters and long distance riders alike. To top it off, the Easton wheel’s medium aero profile helps cuts through wind effortlessly without giving you the typical downsides from crosswinds that you feel from a deeper dish rim. Oh, and of course, red Ti Skewers. I am asking $3,500 for this customized SWORKS.
Components:
Color: Naked carbon Team Quick Step Edition w/Black, Red, and Silver accents)
Frame: S-Works SL2 made with Specialized FACT 11r Carbon
Fork: S-Works FACT monocoque carbon fork; full carbon legs, crown and steerer
Headset: S-Works 1 1/8" integrated threadless, sealed cartridge ceramic bearings w/ stainless steel races, carbon cone and carbon spacers
Handlebar: Zeus CAT III Carbon Fiber with flat top bar, 31.8mm clamp
Bar Tape: NEW Specialized Black
Hoods – NEW SRAM branded in RED
Stem: Zeus CAT III Carbon Fiber Ergo Bend, 31.8mm handlebar clamp
Seat post: FACT carbon w/ Zertz insert, 27.2mm
Saddle: Specialized Body Geometry Romin SL 143mm with Ti Hollow rails
Front Derailleur: 2011 SRAM FORCE Double Braze on
Rear Derailleur: 2011 SRAM FORCE, 10-speed
Brakes: 2011 SRAM FORCE Dual Pivot
Shifters/Levers: 2011 SRAM FORCE with Carbon fiber Double Tap levers
Cassette: SRAM FORCE PG 1070 11-25
Crankset: 2011 SRAM FORCE w/SRAM RED Chainrings and carbon fiber crankarms 53/ 39 T
Bottom Bracket: 2011 SRAM GXP English Threaded
Rims: Easton EA70 w/a medium aero depth
Hubs: Easton C3
Spokes: Sapimâ„¢ double-butted silver, 24F radial, 28R radial NDS/ 2-cross DS
Skewers: Titanium with CNC machined Red levers ~50 grams
Tires: Michelin Krylion Carbon
2008 Giant TCR Advanced 0 ISP Medium/Large ~56cm-57cm - Sram Force and Mavic Ksyrium Wheels
Full set of photos here: http://www.flickr.com/...s/72157629669140595/
I’ve utilized a fully integrated aero wing carbon bar/stem combo for one amazing cockpit, and BRAND NEW Mavic Kysriums in a beautiful glossy white, and wrapped in a NEW set of Michelin Lithion 2.0. I kept with the blue and white theme throughout the build to create a stunning bike that truly stands out in the peleton. The only thing stock on this bike is the frame and fork, everything else has been upgraded with a mechanic’s touch leaving you wanting for nothing in the upgrade department. *Brand new parts include: 2011 Sram Force cranks, Sram Force cassette, Michelin Lithion 2.0 tires, Giant ISP seatmast clamp and spacers, Fizik metallic bar tape. The rest of the Sram Force grouppo only has about 300 miles on it and looks most of the parts just came out of the packaging. I’m asking $3,500 for a well customized and race ready Giant TCR.
Component List:
Color: Team Blue/White/Black & Naked Carbon Fiber Accents
Size: Medium/Large (Giant’s official ML fits riders between 5’10" - 6’2")
Frame: T-800 formulaOne Carbon, Compact Road Design, Giant Advanced Frame Design
Fork: T-800 fomulaOne Full Carbon, 1 1/8" w/carbon steerer
Seatpost: Giant ISP with T-800 fomulaOne Carbon (Brand new seatpost clamp with 10-23 degree offset and a full set of all 4 spacers to give you a wide range of seat height adjustments by simply adding or removing spacers – 74-75cm BB to top of seatpost & 3cm of spacers
Handlebar: OEM FSA Plasma Full carbon fiber Flat top Wing with integrated cable routing and integrated stem - 31.8mm oversized, 44cm width, 120mm reach, 140mm drop
Stem: Full carbon Fiber 90mm - integrated with carbon bars
Bar Tape: Fizik in metallic blue
Saddle: Oval Concepts
Rear: 2011 SRAM FORCE
Shifters: 2011 SRAM FORCE w/BRAND NEW white SRAM hoods
Cassette: BRAND NEW 2011 SRAM FORCE PG 1070 11-23
Cranks: BRAND NEW 2011 SRAM FORCE 175mm Carbon Crank arms, Powerglide Double 53/39 T Chainrings
Bottom Bracket: SRAM FORCE GXP Bottom Bracket
Rims: BRAND NEW Mavic Kysrium Equipe w/white rims
Spokes: Mavic Straight Pull Bladed (Black)
Tires: BRAND NEW Michelin Lithion 2.0 Black w/Blue matching sidewalls
2010 S-WORKS Tarmac SL3 54cm - Dura Ace 7900 and Carbon Reynolds Wheels** * - SOLD***
