BIKE WILL BE PACKAGED AND SHIPPED BY AUTHORIZED SPECIALIZED DEALER.
YOU CAN CALL THE DEALER to confirm authenticity, etc.
**This bike is brand new built. I bought it in 2018. I have never ridden on it, and in december 2018 had a bad wreck on the road bike, broke the hip, etc. so i wont be riding it any time soon.
I converted it to a 1x. though i can throw in the front derailleur. The 1x is superior, same gear range, but far less weight and less change of a dropped chain. And slightly faster, nicer, lighter tires.
it has never been ridden outside, or anyplace. pedals ($300 value) will be included (2019 XTR pedals).
GARMIN computer head and Fly mount for garmin is NOT included.
no blemishes at all. as -new.
more photos:
https://photos.app.goo.gl/VKrpPRoG3oE1nrKDA
Retail is $8500.
Asking $5200 shipped from the bike shop
PM or email me info at superdomesports dot com with any questions
No matter how much we love our full-suspension Epic, it’s undeniable that hardtails still play an extremely important role in XC racing. So what to do? We put our XC offerings on a diet, went back to the drawing board, and created the lightest damn mountain bike we’ve ever made—the S-Works Epic Hardtail.
Read More
To provide the optimal blend of stiffness, crazy light weight, and strength, we constructed the frame from our S-Works FACT 12m carbon fiber. And when combined with our XC 29 Geometry, this Epic is guaranteed to deliver uncompromising, blistering speed and agile handling come race day—no matter the course.The RockShox SID World Cup 29 fork with Brain provides 90/100mm of efficient travel. It features Brain technology that distinguishes between terrain and rider input in order to maximize your power, while a Brain Fade adjusts the oil flow when not hitting bumps.Drivetrain duties are handled by the revolutionary Shimano XTR Di2 11-speed groupset, with 36/26T gearing up front and 11-40t at the rear. The first ever electronic mountain groupset, it provides unparalleled shift precision, reliability, and accuracy, making it the secret weapon in any racer’s arsenal.Technical Specifications
CHAIN Shimano XTR HG901, 11-speed BOTTOM BRACKET Race Face PF30 CRANKSET Race Face Next SL G4, Boostâ„¢ FRONT DERAILLEUR NONE SHIFT LEVERS Shimano XTR Di2, 11-speed CASSETTE Shimano XTR, 11-speed, 11-40t CHAINRINGS 40T REAR DERAILLEUR Shimano XTR M9050 Di2, Shadow Plus, GS cage, 11-speed
FORRK Custom RockShox SID World Cup w/ Brain, top-mount Brain Fade adjust, rebound adjust, Solo Air spring, tapered carbon crown/steerer, 15x110mm Maxle Stealth thru-axle, 90/100mm of travel, 51mm offset
FRONT HUB Roval Control SL, sealed cartridge bearings, 15mm thru-axle, 110mm spacing, 24h REAR HUB Roval Control SL, DT Swiss Star Ratchet, 54t engagement, SRAM XD driver body, 12mm thru-axle, 148mm spacing, 28h INNER TUBES 29x1.75/2.4", 60mm Presta valve SPOKES DT Swiss Competition Race RIMS Roval Control SL, hookless carbon, 25mm internal width, tubeless-ready, hand-built FRONT TIRE Fast Trak, GRIPTON compound, 2Bliss Ready, 29 x 2.3" REAR TIRE Fast Trak, GRIPTON compound, 2Bliss Ready, 29 x 2.1"
SADDLE Body Geometry S-Works
SEATPOST S-Works FACT carbon, 27.2mm, 0mm setback, carbon rail clamps STEM S-Works SL, alloy, titanium bolts, 6-degree rise HANDLEBARS S-Works Carbon Mini Rise, 6-degree upsweep, 8-degree backsweep, 10mm rise, 720mm, 31.8mm GRIPS Specialized Sip Grip, half-waffle, S/M: regular thickness, L/XL: XL thickness
FRONT BRAKE Shimano XTR M9000, hydraulic disc, post mount, metallic pads, 160/180mm rotors REAR BRAKE Shimano XTR M9000, hydraulic disc, post mount, metallic pads, 160mm rotors
SEAT BINDER Specialized Alloy 30.0mm, titanium bolt FRAME S-Works FACT 12m, full carbon frame w/ S-Works layup, XC Geometry, internal split-housing cable routing, PF30 BB, 12x148mm rear end, triangulated post-mount 160mm brake
