FS: Look Keo 2 Max Carbon pedals
Used for just over a year on my road bike. Great condition with only minimal scratches. No cleats included. $95.37 shipped.
Standard description:LOOK Kéo 2 Max Carbon Road Pedals
With a wide carbon-injected body, stainless steel surface area and an oversized axle with dual seals, this lightweight bike pedal maximizes power transfer and reliability. The choice of Tour de France winner Alberto Contador and many other pro-level cyclists.
At only 122g/pedal, the Kéo 2 Max Carbon is one of the lightest pedals in its categoryCarbon-injected body reduces weight and enhances durabilityCleat contact surface area is 12% larger than the Kéo Carbon for a more efficient and comfortable pedal strokeSurface area is made of stainless steel molded directly into the pedal to further improve energy transfer and longevityOversized chromoly spindle with dual seals offers reliable strength and a longer bearing lifeAdjustable Q-factor can be extended by 2mm with the use of specific washers available separatelyTwo ball bearings (12mm in and 18mm out) support axial loads and a needle bearing at the middle of the pedal supports radial loadsAdjustable spring tension mechanism for smoother engagement and releaseKéo Grip cleats use a non-slip surface so you can walk with confidence when you’re off the bikeExceeds the most rigorous testing standards (EN104781) https://lh6.googleusercontent.com/-QgRfvYZgtc0/TmUFv97R-fI/AAAAAAAADBk/p6dCePBaJj0/s640/DSCN0981.JPG
https://lh6.googleusercontent.com/-GSQN_ZHWBCk/TmUF3lRyBuI/AAAAAAAADBw/p1Iu0h7wMY4/s640/DSCN0982.JPG
https://lh5.googleusercontent.com/-x5JMSrO6Z8A/TmUF4i25faI/AAAAAAAADB4/UPZJVinP-cg/s640/DSCN0984.JPG
https://lh6.googleusercontent.com/-_5Y4MGsvjxI/TmUF_WePdTI/AAAAAAAADB8/HDh-CYqBUfk/s640/DSCN0985.JPG
Can you post pics?
Photos available here: https://picasaweb.google.com/emacfar/September52011?authuser=0&feat=directlink
