I’ve got an assortment of items for sale. Pictures below.
First up is a pair of Craft knee warmers. I have used them 5-10 times, but one of the seams really bothers me. Maybe they’ll work better for someone else. Size: Medium. SOLD
Next is a set of red Nokon brake cables and housing. Included are a brand new set of Nokon brake cables, all the metal housing pieces that originally came with the kit, two flexible metal housing pieces that are used adjust the brake levers, a few pieces of liner, a pair of liner connectors, and two clear plastic frame protecting tubes that go over the metal housing. For those that haven’t used Nokons, the liner is a tubing that goes beneath the metal housing and through which the cables run. This metal housing and some portions of the liner have been used. As a result, some of the red pearls are stuck in the clear frame protecting tubes, though the purchaser could easily get the pearls out by cutting the clear tubes (or you could just use the tubes to protect your paint job where the cables rub against your frame). Also, the liner is cut into a few segments, with the longer being maybe one foot. If the liner doesn’t work, you can just buy a new liner (or you can buy Power Cordz, which require a special liner). The housing was not used for very long - maybe 3 months. $35 OR BEST OFFER
A Felt fork. 1" steel steerer, carbon blade. This fork came off a 2006 S22. THe spacing between the blades is pretty wide, so I’d expect it to be decently arrow. There is maybe 8" of steerer. If anyone is interested in an exact measurement I can provide one. Good condition, though there are a few rust spots on the steerer (see the picture below). MAKE AN OFFER
A standard carbon Hydrotail (not the special Cervelo version). Good, but used, conditions (i.e., there are a few scruff marks - all cosmetic). SOLD
Tacx behind the seat cage holder. Can hold one or two cages. The cage holding part is rotatable relative to the part that clamps onto a siddle, so one can rotate the angle of the cages relative to the horizontal. Does not include bolts or nuts for attaching cages. SOLD
