Barely used Orca Sonar wetsuit in great condition. One small fingernail knick that was properly repaired with Seal Glue. Have a Helix now so don’t need both suits. Will fit 5’6" to 5’9" and 147-162 lbs. Asking $175 shipped in lower 48 states.
I know it’s a low ball, and don’t mean to insult you, but its all I got right now. Will you do $110? For some reason I couldn’t pm you. Let me know if you’re interested.
Still Available?
Yes it is.
okay. need to double check on the fit. Ht/Weight wise I’m good. Chest is bigger than 39" though. Any input on how flexible are these compared to the sizing charts?
Alright, I want it. Can’t PM you. I sent you an email.
They’re pretty stretchy… but. I’m 5’7" have a 37" chest (male) and weigh 135 and have a size 6. It works for me pretty well, but I’m on the small side of the range for it. the suit stays attached to my body without taking on water, and I have good freedom of movement. If I gained 20lbs it would certainly still fit. If I grew 2 inches in height it would still fit.
More than 2 more inches in the chest? hard to say- but I think you’d be pushing it. If you’re on the upper end of the size range- it will be skin tight. If you’re over the size range, it could be restrictive, depending on your geometry relative to the suits. I’d say you’re on the edge.
Orca makes a fine wetsuit tho’. Excellent quality. Seams are both stiched, glued and some overlaid with a cover where needed. Extra stretchy panels around the shoulders and calves on this model.
sorry guys, the suit is sold. arrived at my door this afternoon
