FS: '01 TiPhoon Perfect for Xmas
Frame 2001 QR TiPhoon 6Al-4V Main Triangle 3Al- 2.5V rear triangle to optimize compliance and weight (6-4 is lighter, Stiffer and harder to work while 3-2.5 is more compliant, but a little heavier).
Reynolds Pro Ouzo Aero Carbon/Carbon Fork Chris King Headset Profile Design AlumX Base bar, Carbon Stryke Extensions Either a Deda Stem or Profile Design stem (different lengths/rise)
Thomson Zero Offset Seat Post or Profile Design Carbon Razor
Sell Italia gel flow saddle
Cane Creek Brakes
DA bar end shifters
Ultegra Fr Der Ultegra Rear Der Ultegra 12-27 cassette Ultegra Crank set w/ 53/39 chain rings
Cane Creek Aerohead Chrono wheel set
Shimano SPD pedals (if needed)
Profile Design 33g Carbon Cage
Frame and components have some minor scratches, but NO major dings or Dents of any kind on the frame (don’t worry about the shark mouth on the head tube it is only sharpie and will be removed).
The only bad thing is that the carbon cage is permanently attached to the frame due to a stripped bolt and spinning rivet (this can be drilled out and replaced, but it is a nice cage so I just left it on there)
I rebuilt the whole bike 1 year ago replacing all cables, rebuilding Deraillures, bottom bracket and cassette. It has one racing season on it since then and everything is working flawlessly. http://i14.tinypic.com/4bi8cxc.jpg
2K wins the prize come on fellas, Ti frame, sweet bike
Nice bike! You must sleep on the other side of the bed!
S-Back…
What size is that bad boy?
I was always under the impression that this was a 57cm frame. I have measured the actuall dimensions and here is what I got.
55.25 cm TT (center to center)
55 cm ST (center to top)
101.5 cm Wheelbase
40.5 cm chain stay
10.75 cm head tube
From these measurements it looks more liek a 55, but I’m 6’1.5" and it fits me so go figure.
Uh oh, does this mean Litespeed hooked you up with something new? I thought the dog slept on the bed.
No new Litespeed yet. If I could sell this it might help.
Wife does not mind a dog in our bed, but does mind basment full of expensive bikes - go figure.
