Front Derailleur Help! (pic)
My braze-on front derailleur doesn’t seem to lineup correctly with my big chainring - it seem that no matter where I position the derailleur on the tab, the tailend of the cage just barely nicks the teeth. When I shift into the small ring, I sometimes hear it hit the teeth. I’ve raised the derailleur as far as it goes (as in the pic below). Still the same deal. It looks like if I can push the cage back a few millimeters, then the arc will align perfectly with the chainring. Is there such thing as a curved washer or spacer that will fit between the derailleur and the tab? Is there any way to adjust the cage orientation on a braze-on? Help!
http://i12.tinypic.com/2vwverq.jpg
Thanks,
Edward
Back in the day when I used to fly, while going through the landing checklist, I’d always call out “landing gear” then look out the window and respond, “Down and welded”. My friend, your derailleur tab is “down and welded”, and in the wrong orientation it appears - and that is NFG. 'Bout the only thing you could try, if you’re either brave or stupid enough, is to get a precision adjustment tool (6" crescent wrench) and very carefully try to tweak that tab. Problem is, you can’t tweak it in the direction you need to go, so I’d pass on that and try to fabricate a beveled washer to assist in the alignment of the derailleur.
Good luck!
sounds dumb, but is that as high as it will go? It looks like it will go higher-
Weeman
You’re right, it does look like there should be some adjustment left. If not, another option would to be to get a round jewlers file and elongate the slot upwards.
Interesting problem, it seems strange that the derailleur won’t adjust. A curved washer sounds like a good idea, but you might have to fabricate your own. If you can find a 1/16" or 1/8" aluminum washer, you can curve it fairly easily. Put the washer on a piece of wood then take a heavy nail and lay it across the washer. Use a hammer to pound the nail to force the washer to curve to the desired shape. If you can’t find an aluminum washer, you can make one from aluminum sheet.
You can also cut several washers from aluminum cans with scissors and a drill (drill the holes first), just stack as many as you need to get the desired clearance. The force of the bolt should easily force the aluminum into shape.
Frog,
With most front derailleur placements, the bottom edge of the derailleur cage parallels the edge of the chainring along the length of the derailleur cage .
From the photo you supplied, it appears that the tab/bracket that the front deraileur is hanging on is improperly angled to allow this alignment. Clearly, raising or lowering your deraileur will not change the angle of the derailleur cage to the chainring.
There is another possibility and that is that the derailleur cage is improperly angled/positioned on the derailleur arm. But your cage does not appear to have any obvious distorsion to the finish which might indicate that it had been bent as in a crash or falling against something.
I would suggest you discuss this discovery and problem with shifting with the shop you purchased your frame/bike from. If you did not purchase it from a shop, perhaps the manufacturer will assist you. However, if you are not the original owner, the repair and paint touch up may end up being your responsibility.
Yes, an angled shim might help position the derailleur at the proper angle and be a quick and cheap fix but it will probably be difficult to keep the shim from moving over time and your derailleur from moving out of correct position as well.
Good luck. Keep us advised.
“Back in the day when I used to fly”
What did you fly… and why don’t you exist?
Haim
ATP-MEL
CE-500
SA-227
was that derailleur originally a braze-on or was it a clamp-on and you (or someone else) removed the clamp?
Maybe it’s not the same issue, but when I went to a bigger ring from a 52, I had the same trouble. Is this the same ring you’ve always had, is it a 53? If so, would going to a 52 make enough of a difference (I’m not sure - perhaps you could borrow a friend’s)?
I ended up taking mine to the LBS and they were able to do some sort of adjustment - same vendor I’m guessing (Cervelo) and we’ve got the same FD (Dura Ace) and rings (FSA), so you might not be stuck.
Good luck!
-Chris
"Is there any way to adjust the cage orientation on a braze-on? Help! "
Personally…I would just bend it (i.e., ROTATE the derailleur and bracket clockwise as you face it).
You could also shim the portion of the derailleur/bracket interface below the mounting bolt so it rotates the derailleur clockwise.
EDIT: Of course, if this is a new frame/under warranty, then it is the LBS’/manufacturer’s problem…they should bend it for you :wink:
Haim
Is that a Cervelo, per chance?
   ****WARNING:  The following is heresay, and not to be taken as fact.  I own a Cervelo, and love it.****
According to the good people at Maplewood Bicycle (in St. Louis), this is the reason they no longer carry Cervelo.
(Bad) luck of the draw, it appears, on your part.
Good luck getting it taken care of. Seriously.
Steve
Steve
Guess what? I had a similar issue w/ a Soloist…
I’ve heard about this issue from more than a few people, including the guys at Maplewood. And, it sounds like you have first-hand knowledge of the problem.
I threw in the disclaimer more to follow the forum rules than because I doubt that the issue exists (because I don’t).
Having said that… Did you find a solution for your Soloist? If so, I’m sure the OP would love to hear about it.
Steve
Geez, did you have to post your ATP-MEL? :slight_smile: I was (am) just a Private Pilot - SEL, flying 150’s, 152’s, 172’s, an Aero Commander something or another that was similar to a 172, a Beechcraft Musketeer and a Lockheed P3-B (really!). I voluntarily retired from flying (I was 21 at the time), until I could do it right. Right meant enough $'s to fly often and keep the skills really sharp. I’m still working towards that goal. A dream of mine is to have enough land to have a grass strip on it and to own a Super Cub or something similar.
Pretty simple fix, it’s just too far forward.
Shim it back a few mm and then adjust the height.
jaretj
Cut a strip out of a pop/beer can long enough to fold it in half twice and still go across the slot of the derailler hanger. Hit it with a mallet to get the folds nice and tight and then bend it over something to give it a little curve (screw driver shaft). Put the shim between the deraller and the hanger below the derailler fixing bolt, as you are tightening the bolt (be sure to lube the threads) gently wigle the derailler (I usually grab the back end of the cage). No need to engineer any fancy washers or custom adapters, this shim will conform enough to be stable over time. And, of course, you may want your shim to be a little thinner or thicker than the twice folded over, you have my permission to experiment.
My sincere apologies for posting such a nasty/dirty picture…but my Soloist hasn’t been cleaned up in a few months and is very jealous of my new steeds.
My Soloist is vintage, so I’m uncertain if the braze-on was meant to be so dramatically changed (looks like mine is nearly 1.5cm back!). Perhaps you could stitch these photos together, but (as mentioned) there’s a radical difference in placement (which may be due from model years) or might be what was posted above…
Is that a compact crank?
Good luck…
http://tinypic.com/2ppwpab.jpg
I agree. Its an easy fix. Just shim it back a little. The alum can option should work best cause you can cut the stuff with sizzors and it will not rust.
is the bottom bracket the right width? if it’s too wide it could cause you problems getting into the big ring.
i had similar issues w/my soloist. turns out it’s because the bottom bracket is a bit wider than the frame calls for. works ok, but if i change my crank i’m going to get the narrower bb and some pedals that can adjust q-factor to compensate.
-charles
I agree with you. It looks like the braze-on is mis-aligned… a very easy thing for manufacturers to do. It happens quite frequently… though many people never see it because their local shops catch it. It looks like a new bike. Take it back… that amount of error is not acceptable.
A curved washer may work, but you’re gonna have some fun finding one that is correctly shaped.
