Front Derailleur Conundrum
Hi, whenever I shift my bike into my granny gear, then try to shift it back out, my derailleur has serious problems pushing the chain back on to the big chain ring. If I manually push on the derailleur, it moves to the proper position. Obviously I can’t do this when I am riding a bike, so any help would be appreciated.
Could be a number of things
  1. Your front der is aligned to the chainrings wrong. Re-align the front der.
  2. Your front der is not functioning correctly. Try lubing the pivots.
  3. Your cable is bad. Replace the front der cable.
I would take it off, undo each hex bolt and lubricate each moving part. Once you have done this you can put it all together and it should shift more easily.
Too little cable tension probably.
If you want your shifts quick, try bringing your front derailleur as close to your chainrings as possible (leave 1-2mm gap between the front derailleur cage when it swings out and the big chain ring). Also, make sure the derailleur is angled properly… front of the cage parallel to your chainrings. More details can be found here: http://sheldonbrown.com/derailer-adjustment.html
tri bike or roadie o mtn bike? bar end shifters, or sti/ergopowers?
This is a tri bike, less than one month old, with new cables. The derailleur is adjusted properly in terms of positioning, because after I push it into the right place, it sits just fine.
What does “sits just fine” mean, specifically? How much clearance is there fronm the outer cage to the chain? Also, certain chainrings do not shift very well. Shimano ranks at the top, IMO. FSA is generally not quite as good.
I’m assuming that there is no slack in the cable when the shifter is all the way down (in the small ring). You may also need to adjust the hi - limit screw slightly. What happens is that shifting is generally much smoother on the workstand than under load, if the hi-limit screw is too tight, there may not be enough cage movement there to overcome the flex in the front derailleur / chainrings to get the chain up to the large ring. by backing off the screw a tiny amount, it may help.
Note that where the chain is on the rear cogs also influences front shifting. For example, when in the largest rear cog and shifting from small chainring to large, there is a lot of chain tension created from an acute chainline angle. That chain tension increases friction which is working against you as you try to shift up. Conversely, that same chain tension can cause a dropped chain when you shift down from big to small ring when on the big cog in back.
One thing that happened to me recently was I had my FD cable attached incorrectly to the FD. I didn’t have the cable wrapping around the screw (so to speak) and then pointing twd the outside. Instead I had it attached vertically. Long story short when I would attempt to go into the big ring there wasn’t enough leverage to move the derailleur all the way.
Its a quick fix and worth checking.
Best of luck.
-Tim
what are the ring sizes? If you’re going from 39 to 55 you would have some problems.
