I just replaced all my cables and now am having problems adjusting the front deraileur. I’ve read everything from Zinn to Park tools on how to make this thing work. Specifically, it appears that the cage somehow shifted where it is now raised in the front and running low in the back. The derailuer is fixed to my kestrel frame by two bolts so I can’t rotate it to make it even. Is there an adjustment screw to readjust the cage to make it even so it will be 2mm above the large chainring from front to back?
Come on show some love
Clamp on or braze on? Odd man…odd - could be your lack of replies is that it sounds odd - got a camera?
Braze on. I will get a picture up
We will of course wait for you to clean your house and get a suitable backround for the image.
I got my wife on the vacuum I’m hoping in the shower and pressing my shorts now
You might have to shim the bottom of the derailleur in the clamp to equal the distance around the chain ring.
Unfortunately, I’m having problems posting a picture of this annoyance. I’m so pissed, before I became Mr. Wrench and decided to change all the cables and housings the front derailuer worked perfect.
