Front der. adjusting?
I believe the cable on my P3 has stretched for the front derailer. I’d like to fix this myself. Is it just a matter of loosening the cable bolt and pulling the cable a little tighter? If so, what gears should the chain be in while doing this?
Thanks
Adjusting derailleurs isn’t hard at all, but you have to know how to do it properly or you’ll just make it worse. If you go on the Shimano web site you can print off the instructions for how to do this.
Or the park tools site.
Is there not a cable tension adjustment “bolt”? Should be on the downtube (but not sure since the P3 uses the internal routing). If so, turn COUNTERCLOCKWISE to tighten the cable.
