From Zero to Hero
I am a Duathlete and am proud of running hard and cycling hard…but to be honest, im looking at it logically and the truth is Duathlon is not as respected as much as nor any where near the amount of Triathlon…So i am going to dip my feet in the Triathlon waters ,pardon the pun ;^)
But…not that im a terrible swimmer but i know i would not come in at top 40 % of swimmers and i want to be competitive. In the du’s i am very consistent in my times but i know the swim will not be near the quality of my run or bike…
So…is there any people out there to turn my 2min /100m ( coming out of the water exhausted ) time into that of a 1:30min within a year ( coming out of the water energized ) time. Any Advice
One more problem…i am not heavy ( 155 lbs ) howeer , i have a large percent of muscle…really helps on the bike and run :slight_smile: but is it gonna kill me on the swim?? or will a wetsuit pretty much take care of the floating without excess energy spent problem?
Top triathletes are also fairly muscular. Becky, Macca, and Pottsie aren’t relying on body fat to get them through the swim. Swimming is all about form; you can’t generate enough watts to overcome the drag of a poor body position. Unlike running and biking, just going harder won’t make you significantly faster. Get a coach to help you with body position and stroke mechanics (not someone to help you with a workout plan…that’s later). Film your stroke (even a cheap digital camera takes video these days)…and be prepared to look back and laugh at the form you started with.
A couple of basic tips:
Press the T (focus on staying level in the water).
Rotate with each stroke (turn your body to breathe, not your head).
Keep your head neutral (i.e. in line with your body, looking down at the bottom of the pool midstroke).
High elbows (your hand should enter before your elbow. pull the water, don’t pet it)
