Forerunner 305 registering speed when stopped?
Rode Saturday for the first time with the Forerunner 305, and had a couple problems. While at the rest stop, it was registering various speeds, 0 to 1.2 to 3 etc. The auto pause had it coming on and off. I turned it off and on again, but then had the second problem.
It registers the correct speed while riding, but ever time I stop it showed 19.2 mph. Every time, same numbers, so wouldn’t auto pause. had to do it manually, and of course missed one and lost a couple miles, blah blah.
My partner has the Edge 305 and mentioned maybe I needed to smooth out the signal. He couldn’t remember how he did that, of course.
Running, seems to have no problems. I have version 2.50 of the unit software, which seems to be the latest, but there is some additional software as of 1/16/07 that I doubt it loaded.
Anyone have this problem? Solutions? bad unit?
Was there anything goofy going on in the sky? That sounds quiet unusual as mine will autopause and (using a similar method) auto-lap just fine.
If you use motionbased, I think it can correct for moving/nonmoving.
I’ve forerunner 305 too, and my question is… do you thing that the total session climbing when you run is correct?
No, clear blue sky, and my friend’s Edge 305 was reading just fine.
Running, as far as I can tell, is accurate.
Try going in to the settings and turning off or turning down pace/speed averaging, that might help.
Perhaps just a bad day.
Also, you need to delete all the history on it from time to time as when it runs out of memory it can cause data recording problems.
Thanks, will try that and updating the software and test it out again tomorrow am.
Pretty sure it’s not memory since it was only the second logged workout
Weird, mine’s never done that…if you’re moving your arm it might explain the initial low readings while parked. I think I may have altered the smoothing settings on mine when I got it based on something I read on here. I don’t think I have the latest update which supposedly improved the instantaneous pace measuring, I mainly use it for running and go off the lap pace if I’m doing intervals.
it is a computer in the end and they all do stupid things once in a while. Reset, turn it off and back on and these things usually go away.
Last week I had my 305 on my handlebars as I did a trainer workout. I did a 1.5 hour workout and it said I went .25 miles total. It’s all about the accuracy of the GPS readings it gets. It’s not 100% accurate.
