I am short 5’6". So naturally my bikes come with 170mm crank (I am in the process of building a new mt bike). My issue is that I have a large inseam for my size 31.5". In addition, I have a longer femur than tibia. Therefore when I go to set up my seat set-back It is pretty far back. Because I use a Flite, with shorter rails (I tried all types of saddles & this is the one my butt likes best) it is at its limit.
So my question is: should I go with a longer length crank? My theory, having no fitting experience besides what I have read, is that the longer crank will help me have that extra little bit I need when aligning the knee with the spindle and perhaps give me a little more leverage. When I spoke to the guy building my bike, he stated that since I am used to riding 170s I should stick with them.
My riding style: I am a masher, but have trained myself to spin & when climbing I like to scoot way back on the saddle (from what I read this is typical of shorter people.) I am also a climber and am one of the first people up the hill, even though I may carry an extra lb or two. However, I am not a diesel and my weakness is sustained power on the flats.
I have a 37 inch inseam and just went to 200m cranks. I LOVE them, and am faster!! But, most on ST will tell you its all in my head and the numbers are not real. :o)
You mentioned you ride a 170. I assume that is for road.
Personally on a Mountain Bike I like to go one or even two sizes smaller. Just like on a track fixed gear you don’t want to hit the embankments, so smaller crank/smaller (compact) front rings. Mountain Biking is high cadence for technical trails and shorter cranks help that, plus they stay out of the way of obstacles.
I take it you don’t ride competitive on a Mountain bike, at least I never heard of a masher being a mountain biker, at least not on technical trails.
Dave
And as the studies, and studies and studies have proven… they are correct…
It is impossible to find consensus amoung cyclinsts on this topic, and there are contradictory scientific studies as well. I think you should go with what feels right, which can be expensive if you are swapping out cranks to do that. I found the crank length formula at http://www.nettally.com/palmk/crankset.html to a good start to determine a baseline crank length. I also agree with the simplified crank length formula in Joe Friel’s Triathlete’s Training Bible.
This is a question I’ve struggled with for a long time. In talking with people in the fit industry who I respect, I find that most of us come to a consensus. I adjust crank length for comfort. For example, if someone is having either lumbar or pelvic discomfort and all their fit coordinates are in order, I may try a shorter crank. Why? At top dead center of the crank rotation this angle is not quite as acute. My data on this is purely empirical. I’ve had positive feedback when I’ve experimented with this so far. Some people with power meters have stated an increase in power, but this is obviously hard to attribute to the shorter cranks. First off, it’s obviously not a controlled study so the info is HIGHLY subjective. Even if we assume the subjects are correct and their power is higher, it may not be directly because of shorter cranks. If the shorter crank allows them to be more comfortable and less fatigued, then perhaps this allows them to produce more power. Either way, if the position is more favorable for the rider, then I believe it is the “correct” position for that individual. At the end of the day, I still don’t have any very good reason for choosing a crank length to start with other than a person’s size. From there, comfort and rider feedback is my gauge for adjustment.
Not a fitter but my road bike came with 172.5s. I usually ride 175s. It definitely felt different for me and after a few months I put 175 on there and it felt instantly more powerful to me. And yes, I adjusted the seat height because of the crank arm lenghts.
Some may say that the difference is too small. I don’t think there are any studies out there that conclude anything. But I cannot believe that there shouldn’t be a difference. If you would put 150s on there vs. 190s you would notice a difference, and one would be better for you than the other. Why wouldn’t the same hold true for 170/172.5 vs. 175?
