FOP (top 5%) AG IM bikers - what is your FTP per kg?
3.9 W/kg. But everybody knows that only the run matters.
Amen! Same here though, right around 3.9 W/kg, 10th amateur bike split at IMTX '13.
Im ~3.9 W/KG…was 13/349 on the bike in M45-49 at IMLP
Top 5% in finishers or bike split?
My first IM I did 5:18 at MT at 210W @ 75kgs = 2.8W/Kg. Felt great afterwards so I think I was right on. Went too hard at the of the run and blew up having to walk most of the last 5k with trashed legs. I think it was more of a run training issue and felt that my bike was bang on. I did a crude FTP test and got 265W so that would give me 3.5W/Kg at FTP. I never did any interval workouts during training so I will be working on that for next year. I think I will aim for 230W for my IM next year. I figure I will need to get my FTP up to 290-300W this winter.
A more pertinent question to ask is what is their p/CdA #'s. I have numerous powerfiles from numerous races where someone rode 2.8 or 3.2 and outsplit someone riding 3.4 or 4.1 w/kg.
Power matters, but on the majority of triathlon courses a lot of triathletes make it easy to out ride them by having bad CdA numbers either through position and/or by junking up their bike with shit hanging off it everywhere.
Nailed it, three trip to the wind tunnel for me was better then worrying about my w/kg. Now I can slip along and stay fresh for the run.
My bike splits are usually the top 1-2% OA of whatever field I’m in, and I usually race at 4+ w/kg.
Currently calling it ~285w/70-71kg
Was 4.2+ w/kg back in '11 (295/69), when I biked 5:09 at LP, and also had one of the fastest bike splits at Savageman (where w/kg actually matters, a LOT!!)
I’m pretty aero, so I’d imagine my w/CdA is pretty decent too.
I’m right about 4.2 W/kg and usually place pretty well in the M50-54 AG bike splits, I’d say top 2-3% typically.
1225 watts/CdA
Hahahaha, awesome.
Let’s see:
4.3 W/kg
1476 W/CdA
Needless to say, I do quite, quite well on flat and windy races. Never done an IM, but I’d imagine extrapolating FOP AG’ers HIM performances to IM is fairly good.
I think it also matters if you are 180 lbs or 120 lbs. Let’s assume both move 700C wheels through the air. For the 120 lb rider, that is a bigger percentage of the top line watts than the 180 lbs rider. Given that almost all IM courses come back to here you started and are not done at Alpe d’Huez, the larger rider will win at the same watts per kilo even if both have the same clean aero position and gear.
I am in the 45-49 and these days my i am at around 345 or 3.9 watts per kilo - i weigh 85.kg.
Had mine measured for first time at start of build a few weeks ago at 4.22watts/kg… Hopefully it creeps up a bit towards IM Busso :slight_smile:
I only weigh 58kg.
Perfect timing. Michael was 3.9W per kilo and around 6’5" (85 kilos). I was just under 4.2 W per kilo at 5’6" (62 kilos). Michael biked 10 min faster than me (bike time) at 70.3 WC in Tremblant. Top line watts matter. We’re both pushing the same size wheel through the air.
For sure Dev - as long as the courses are not to hilly i have known from the day i first starting riding that being big gave me an advantage on the bike. This advantage was a nice offset to compensate for the fact that most of the best runners seemed to have a natural advantage on the run leg. That was one of the reasons i was excited about triathlon in the beginning. It was a chance to get back at the fleet footed runners that couldnt generate the power they needed to kick my ass on the bike. The amazing to me is the guys that go so fast with low numbers by being so damn aero - that is hard - respect!!!
I was around 4.4w/kg to end the season, but have only biked once in about 2 weeks since 70.3 WC. I rode at ~3.7w/kg there (286w np @ 77kg). My goal for next season is to try getting down to a race weight of around 163 lb (74kg) so I can get to around 4.6 at FTP. I rode a 5:06 at IMMT last summer and my goal is to be under 5:00 next summer. I imagine 245-250 watts should get me there.
My bike splits are generally near the top OA at local races and top of AG at larger races. Quite humbled to be smoked at Tremblant, though. I’d imagine some of the top AG athletes there were riding around 300 watts (not including ‘el doper’ Colom who was probably around 350).
If I recall correctly Jeff Symonds, biked 4:51 at Whistler off 240W at 165 lbs. so you’re getting close to that range if you can shave off 6-8 lbs. Whistler is a tougher course than Tremblant, but more of a watts per kilo than watts per Cda. It has 300m more of climbing but all the climbing comes on “real hills” where aero does not matter. At Tremblant you do 2/3 of the elevation in the first 72K while being bolted to the aerobars for all but 2K. Next 9K aero does not matter than much and final 9K aero is the only thing that matters.
Dev
…and Tremblant 70.3 WC was probably not a great example. I bet several of the guys you raced that day there would be a larger delta in a race with lesser depth of field. Many of the smaller guys get a much better benefit even at legal distance. I rode the same NP in the fall versus the spring race there, and biked 9 min faster. Now some of that was from aero adjustments, some of it from bette helmet for me, some of it from being lighter, but at least 5 min there was from just being around more guys my speed vs being totally solo at the spring race for 87 kilometers. The smaller athletes benefit more (relatively) when the field is dense because you cannot get as good benefit from your top line power.
This is also why in Kona on a really windy days, the larger pros have more of an advantage than the smaller pros, because there is less draft benefit at legal distance with big cross wind. Look at the years that Crowie won and they were generally low wind years.
Mine was 4.0 where I rode a 5:00 and was able to do that split with relative ease which put me in the top 3% overall. My training could have been far better however as I did little to increase my FTP and focussed on endurance.
This year I am targeting 5.0 - 350 FTP @ 70kg (154lbs) this should bring me in around 4:35-45 assuming similar conditions.
3.9ish, CdA around 0.2 though.
4.0 w/kg
Top 2% AG @ IMLou
5:04:38 bike split
7th fastest bike split (overall amateur), 2nd in AG at my last Ironman @ 3.7 (340 FTP @ 203 lbs).
and of course it should be expected that on flat courses, big guys will do well with less watts/kg and tiny people will need more watts/kg!
Yeah the flats suck for us small guys. I’m at 3.7w/kg but that is only 244w at my weight, I know people who have way lower W/kg but they smash me on all the flat strava segments.
