I know that it is only an indicator, but curious to know what the people with a top 5% bike split in their AG has in terms of FTP per kg?
Around the 4.4w/kg range
Edit: that might be more like the top 1%
So maybe 4.1w/kg +
That’d be freaking awesome.
Yeah I wish I could do it
I do pretty well on the bike, and mine hovers around 4.6-4.7 W/kg. I’m quite light so that makes it pretty reasonable to get there.
8th best bike split in my AG @ IMWI…3.9 w/kg.
It’s been a while since I competed but when in top 5% it was about 4w/kg
Not sure how I’ll rank next Sunday, but I’m just over 4.5w/Kg right now thanks to Accelerate3 whipping the snot out of me all season.
For what it’s worth, seems like I was around 20th M30-34 at IMCa’13 with 4w/Kg FTP and road a .69IF
At IMMT, 5% in the 25-39 AGs was 5:10-5:20 or so - 34.8km/h = 21.6mph.
According to the post your speed/watts thread, you can achieve 21.6mph with between 2.5w/kg and 3.3w/kg (I got this by eyeballing the bulk of the scatterplot at the 21.6mph level).
Let’s assume that most of the data points in that thread are exaggerating a bit or aren’t achievable while carrying IM-style nutrition, so we’ll bump that up to say 2.7w/kg to 3.5w/kg to achieve the goal pace.
Most advice I can find with a quick googling says to aim your IM bike pace at around 70% of your FTP. So the guys maintaining 2.7w/kg to 3.5w/kg will need FTPs of 3.8w/kg to 5.0w/kg depending on their aerodynamic efficiency or chosen %-of-FTP target.
So it sounds like both Jackmott’s estimates were in the right ballpark.
4.1 but how competitve that is depends on the course. I’m a bigger guy so on a flat course my watts put me higher in the standings, on a hillier course not so much.
I was @ ~4.7 w/kg for the last 2 IM races I did, and that gave me the best amateur bike split at IMLP and one of the best amateur bike splits in Kona. jackmott is probably right that something in the low 4s will put you in the top 5%.
There are two ways to interpret this question:
What is your w/kg at IM distance?For those who are in the top 5%, what is your w/kg at FTP?
As a front of the pack cyclist, but not IM competitor, I’m around 4.8 for w/kg. If I balanced three sports I doubt if I could keep it above 4.5.
7th fastest bike split (overall amateur), 2nd in AG at my last Ironman @ 3.7 (340 FTP @ 203 lbs).
and of course it should be expected that on flat courses, big guys will do well with less watts/kg and tiny people will need more watts/kg!
Top 10% here. 3.79 watts/kg at race time
4.1 w/kg (167lbs, 308FTP… 5’11"). Usually around top 1%. Hope to drop some weight next season, gain a few watts (If I can do both… otherwise I’ll take the weight loss so I can run faster) and get closer to 4.3 - 4.4.
IMWI - 3rd fastest AG bike split.
Steelhead -3rd fastest amateur split, 5th split overall. (Though I’m pretty sure later swim waves were aided more by the wind that the pros)
Kansas - 2nd fastest in AG.
First year riding over 100mpw average, riding consistently more that 3 times a week and really hitting the trainer in the winter… so that helped. Will be interesting to see what i can do next year. Volume won;t go up much, but I should be able to build form where I’m at.
A more pertinent question to ask is what is their p/CdA #'s. I have numerous powerfiles from numerous races where someone rode 2.8 or 3.2 and outsplit someone riding 3.4 or 4.1 w/kg.
Power matters, but on the majority of triathlon courses a lot of triathletes make it easy to out ride them by having bad CdA numbers either through position and/or by junking up their bike with shit hanging off it everywhere.
Been top 5 or so overall bike splits for AG in 3 IM races this year. I’m around 4.1w/kg FTP.
That’s a good point. I think you’ll find a fairly wide rang of CdA out there. Even among pros. Pros with 3 bottles on their bike plus a 4th as a flat kit in an IM.
3.9 W/kg. But everybody knows that only the run matters.
Now, if I can use my weight at the end of the race, that’s >4 W/kg!
