i find it interesting.
would that be $1,500 per passenger or per-bike-bringing-passenger? for me, going PHL to SLC or similar, i’d say that’s reasonable. but if you need to cover each passenger and you probably will, i can’t swing $3K for me and the missus.
if you go the route where its all competitors, can your aircraft support 10 passengers and 9 bikes? they are light but they are cumbersome.
It would be 1500 per seat filled on the plane, doesnt matter whether you brought a bike or not.
The aircraft is a Pilatus PC-12, the way the plane would be configured, we would have an extremely large cargo area. We may only be able to bring 7 passengers total but it would be a very comfortable ride (still ironing out numbers). The Pilatus has a massive payload per range and flies fast for a Turboprop at roughly 300mph, very economically. Hence, the low fee of 1500 dollars. We think it would be the right combination of luxury, price, and functionality.
We are really just fishing for opinions, what people think of the idea.
Ok, this is becoming entertaining. I was going to stay out of it. As much as I would love to see you pull this off, Pilatus PC-12 is not your aircraft for the mission. While you are trying to keep the lid on the cost, there using PC-12, you are running into max payload/ max take off weight issues, cabin volume restrictions even though I agree, it is the biggest in it’s class. You are not fitting in there 9 people and 9 bikes, not even 7 and 7 with all the gear.
On the second note, with that load, you are running up against the stage length and clearly now running into SWA territory, $300 ticket+ $50 each way for the bike case. I hate to tell you, make sure you do your math correct. Many so called aviation industry executives have failed at this, including a failure at operational cost level. I have been in it for too long and seen in too many times.
I do like your idea, but I am not your potential customer.
And than there is the good old stereotype, “oh, single engine truboprop…” You know what I mean.
Good luck.
