Flood advice - attention plumbers, contractors, home insurance agents, adjustors, lawyers
OK, just so we’re all on the same sheet of music here… That pressure relief valve has nothing to do with gas.
Pressure relief has everything to do with gas.
On a more serious note, I know. My hypothetical scenario is the WH blowing upwards like a rocket, severing its gas line supply, and then the leaking gas exploding in a secondary explosion.
Hmm, I wonder if that is what happened to the house down the street that burnt down a few years ago.
patf - there is a circulating pump on that line, so it was probably feeding water TO the WH. Why it reversed, and started feeding water FROM the WH into the galvanized, is what still remains a mystery.
I might just cut it off and examine the inside of the pump - doesn’t that sound like a great idea?
Don’t cut anything till you’ve decided you are going to eat this problem yourself. I like your theory that the recirculate valve started leaking and water flowed back into the copper and then galvanized pipes. I think the plumber should have seen this and disconnected it when they did the lex install. Call that plumber and have them come look. If you cut if off first, you will make it harder to make claim against plumber.
I do not think they looked at the WH much at all. The PEX lines to it are connected on the inside, and I do not know if the copper between the WH and PEX was there before, but I suppose so (as other water lines in this addition section of the home had copper also).
Thank you for finding that diagram, that is exactly what we have I believe (or had, before the PEX was put in).
NO, the recirculating line was NOT disconnected in any way shape or form. It was left untouched. The end of it near the farthest fixture is in the attic, in a VERY visible place, immediately next to the attic access, with the PEX lines running next to it, so plumbers in the attic must have seen it (but probably not recognize what it is).
So then either that check valve or the recirc pump gradually failed over time, leading to the back flow now.
BTW, the PEX was installed 2.5 years ago.
it sounds like something they should have scoped out and fixed better. I.e. remove those lines pump etc.
FYI, I am replacing my lines with PEX soon. I am not doing it myself as I want to get it done quick and all my previous experience was with copper /galvanized lines. I have those water lines that sometimes burst. 5 out of 50 houses in the development have had problems so it is time to replace.
I feel like I am now armed with the information I need. Here are my potential ideas for plumber negligence.
  1. leaving uncapped cut galvanized pipes in the walls.
  2. not recognizing the hot water recirculating line still attached to the WH and not disconnecting it
  3. recognizing the hot water recirculating line, but not telling us, hoping that the check valve and pump will keep the water from backing up, and not telling us about the dangers of opening the blue handle. THIS WOULD BE A CAPITAL OFFENSE definitely punishable by pipe wrench beating.
All faucets, including washer, have hot water. This third water line out of the water heater goes straight without branching into the galvanized line in the attic. It seems its purpose might have been to get hot water to that end of the house faster (its where the master bathroom is…the water heater is on the other end of the house)
Is this copper/galv line to the far side of the house the only line to feed overthere? Maybe this was a way to be able to shut off water to that side of the house. would be really weird (as if this setup is not odd enough) if you can (or could) run inside the pipe, all the way from the Hot outlet on top, to this hot (oultet now) on the bottom. Would mean both were feeding the same pipes.
Wait… is there a pump somewhere on this line… maybe this was how someone attempted to install a feedback (re-circulation) line. You call for hot water, the pump starts running, sending the now cooled hot water back to the heater, then when the new water getting to the valve is truely hot, the outlet opens and the pump shuts off. Maybe this is how some DIY feed the return line into the water heater?
Sounds to me like you didn’t even know you had a re-circulating pump on the system. When you asked the plumber to replace all the piping that would, at least to me, indicated ALL the piping including the recirculation system. If they either ignored that system, didn’t know what to do with it or worst case improperly plumbed around it in an attempt to have to not take it out and left something attached to it it all sounds like they may at least be a little liable. If however they said something about it and you did not know what they were talking about it is probably on you.
~Matt
I think you should clean-out from around the flammable fire thingy, when you get a chance.
Also, most of the hillbillies that I know are pretty damn good with things like hot liquid boilers, pipes and valves. I wouldn’t blame a hillbilly for that mess.
yes, we have figured it out, it was a recirc line, it has a pump on it
believe me, there was NO talk of this recirc line
i would remember because I was EXTRA nervous leaving all that uncapped galvanized piping in my walls……I remember I kept asking them if there was any way any water could get back in
if I had known about this recirc line back then, I would have just told them to cut it off the WH. It would not have added any cost at all.
what flammable fire thingy? tinder? where?
Its a gas water heater, right?
yup, its gas, there is a fire burning inside and everything
Is that some leaves at the bottom in the pictures? The fire is very near the bottom so is suppose some fire could start if there was debris there.
sure thing, good idea, thanks (I was hoping the drip drip from the black hose would keep the leaves moist enough not to catch fire)
you think I should get my leaf blower out to do it?
there are 3 water lines on the water heater. 1 PEX cold water in. 1 PEX hot water out. These two connect at the top.
There is a 3rd copper line attached between two faucets/valves on the bottom.
http://i58.tinypic.com/11rya2b.jpg
I have no idea how long the blue lever had been on the “open” setting, why it was like that, or what. We never mess with the water heater, its outside and we never maintain it or anything (bad, I know).
This copper line is tied into the old galvanized lines that have theoretically been disconnected when the PEX was installed. Except this copper line was feeding water into the galvanized, which then was dumping the water into the wall out its open end (where it had been cut off to attach the PEX to the angle stops under the sink). When I turned on the main water to the house, the galvanized started dumping water into the wall. After turning the blue lever to off, and draining the water out using the green faucet, and then turning the main water on, there was no more water out of the galvanized. (I also went up in the attic and saw where this 3rd water heater copper line actually feeds into the old galvanized pipes, which were just left in situ in the attic)
So would a decent plumber not have recognized this was going to be a problem?
Uhm… that water leak could be the least of your concerns. How do leaves get into the utility area?
the water heater is outside….the wind blows, the leaves go here and there…
So the plumber just left, and our conversation was very unproductive. (my husband will be calling the owner of the company tomorrow, if that goes nowhere, we will post their names and this all over the internet….)
He basically said:
  1. they never cap the cut ends int he walls (and they have no intention of ever doing that)
  2. they never check the old disconnected water system for things like a recirc line
  3. they didn’t look at our water heater at the time of the install
He did not have any answer to how a licensed and experienced plumber would not see the recirc line, when he is working all around it (at the far end, it is very very visible, next to where they were working, and on the WH end, the recirc line is immediately next to the two lines they connected to the PEX), and basically made some derogatory comment about how the previous homeowner who put in the recirc line must have been a dumbs, and who would do such a thing etc etc.
He showed no remorse. He did not say anything to the effect that our experience may have taught them something, that may help them avoid disasters like this with other homeowners in the future.
