So
Flo Disc (clincher) or Wheel cover (clincher)
Advantages for 5:30 range IM bike
So
Wheel cover for me.
Advantages - as fast (or close enough to as fast) as a “true” disc"
<$100
PT wheel doubles as training/racing wheel
I say you put a wheel cover on the Flo Disc to get the extra Moment Of Inertia the added weight will add. Since you are getting clinchers, I’d recommend 25mm tires because wider is always better on rear wheels, especially if you are riding a tri bike.
should I use gator skins for a little extra weight and MOI
:0)
So
Simply take the cover off when you KQ
Used the Flo 90 with a cover this year. But it was such a PITA and the disc is relatively cheap, so i’m picking up the disc.
You forgot the pink font. Oh, I know, it’s left out intentionally to see if you can pull a few legs…
