Flats on trainer
I was just wondering if anyone else seems to flat when on their trainer.
I have been riding on my trainer this season (about 7-8 times) and after my last ride, I had a flat. I have not ridden on the roads in between these trainer rides on this bike. This happened a few times last winter as well. I would replace the tube, check the tire for any sharp foreign objects and then pump up the tire with the new tube, go for a ride on the trainer and then next day go to put my bike back on the trainer and…FLAT!
Any thoughts?
spend a few dollars ($2 or $3) and invest in rim strips.
May also want to back off on the tension of the trainer slightly
more than likely - rim strips will help you out and resolve the problem
Yeah, I have velox cloth rims strips. Is there anything better out there that you would suggest?
My trainer has a spring-loaded roller wheel, so tension can not be adjusted.
