Flat feet and Cycling shoes
How important is it to have arch support in a cycling shoe, when you have low arches and use stability shoes to run in. I have noticed that my cycling shoes (Sidi) are pretty flat and have no support.
Thanks
I think it is very important. I started to get some plantar fascitis when I stopped using orthotics in my cycling shoes. I noticed my arches were very fatigued after cycling without the support. Additionally, without orthotics your leg might not be in good alignment when you pedal which could cause some knee pain.
Depends. Some do fine, others do not. Just because you have a “flat” foot does not mean your need any extra support (especially in cycling shoes). It does increase your odds though. Orthotics main function is on the subtalar joint (which gets little use in a stiff soled cycling shoe). Some soft tissue/arch tenderness, if noted, does respond well though to “arch support”
I have flat feet too.
I do what Gallaway recommends which is old school…get some paper and tape and build up the arch support for your running shoes. I also do the same for my cycling shoes. I guess you could call 'em poor man’s orthotics.
Adds hardly any weight compared to custom orthotics…yet seems to work well.
A PT told me that arch support is just as neccessary for cycling as it is for running.
