Fi'zi:k Gel Pads Specs
For those looking for more info not yet found on the fi’zi:k website:
Here’s some tech info for your.
 **Gel pads features** **                        ** **features:          ●shock absorbing, washable, re-usable** **                        ●cut-to-fit-compatiblity** **●won’t leak, won’t harden, won’t migrate,        won’t break-down** **3 models:         3 distinct cut-to-fit shapes      ** **weight:             76.5 grams, 88 grams, 105 grams** ** ** **MSRP:              $29.99****** ** **
TRI GEL:PADs come in 3 distinct shapes that are compatible with at least six of the most popular aerobars on the market. Since the pads can be CUT TO FIT without leaking or without destroying the product’s integrity, the pads MAY fit with additional aerobar products on today’s market. ****
The pads have a small layer of Velcro-compatible-material (to attach to armrests) and and approx 2.5 mm of Technol® gel. Total thickness of the gel pad is approx 5mm.
J**THREE DISTINCTLY SHAPED MODELS that CUT-TO-FIT with **
· Syntace Biowing, Profile Venturi
· Vision Deluxe, Vision Micro
· Profle F19 & Profile F22
èshock absorbing
èwashable
èreusable
èattaches directly to your original armrest Velcro
èTechnogel® won’t break down, migrate or harden
For those that want to know what TechnogelÒ is:
Technogel is a non-silcone based gel that exists somewhere a liquid and solid.
Zero silicone = (0 migration + 0 hardening + 0 separation) = lifetime consistency = comfort.
TechnogelÒ is the world’s leading gel producer. It is superior due to its shape memory. Shape memory is an exclusive characteristic of TechnogelÒ. When pressed, the gel moulds itself to the individual’s shape by deforming along three axes: horizontally, vertically and diagonally. Other gels can only deform to the up-down direction, eventually increasing pressure in this contact zone.
TECHNICALLY AND INDUSTRIALLY: Because TechnogelÒ uses no silicone and is a non-toxic, volatile-agent-free material, it will never harden, migrate or breakdown. It will maintain its elasticity and shape memory characteristics infinitely. Existing in a state between a liquid and solid, it will never leak.
BENEFIT: The gel’s ability to balance pressure distribution translates into tangible, physical benefits. Shape memory yields better blood circulation and the ability to maintain bar position without continuously searching for a more comfortable position. It also means less vibration, therefore, less shock transmitted through the hands, arms and shoulders. GREATER COMFORT YIELDS IMPROVED PEFORMANCE.
Cheers. Hope that helps.
Suzette
