Ok I have a pretty interesting question here that may or may not fuel some good discussion. Since coming to slow twitch I have learned a lot especially about bike fitting which is pretty interesting to me b/c everything I am reading is telling me that I am on a bike to big for me. I am 5’5" (on a good day!) and would not consider myself to be of the “torso impaired.” I have read the latest article about “fitting small bikes is tall order” and everything that I read seems to point that I should be on a bike somewhere in the neighborhood of a 48cm. I currently am riding a 52cm Specialized Allez that I have converted to a tri setup but I hope to maybe this year spring for a new bike and although I hope that I can maybe get a fit done prior to buying. Anyway to get back on track I saw someone post the competitivecyclist.com has the fitting calculator so I decided to go to that and put in my measurements and see what it told me. After all it might help me see if I’m better suited for a cervelo or a QR right? Well heres my digits and what their fit calculator came back with.
Measurements
Inseam: 32
Trunk: 24
Forearm: 13.5
Arm: 26.5
Thigh: 22.75
Lower Leg: 21.5
Sternal Notch: 55
Total Body Height: 65.5
The Aero Fit
Top Tube Range: 52.9 - 54.9
Stem Length Range: 8.0 - 10.0
Saddle-Bottom Bracket Position: 73.2
Saddle-Pedal Position: 90.4
Saddle-Ground Position: 98.2
Cranklength: 170.0
Aero Bar Size: M
Saddle-Aero Bar Pad Drop Minimal: 4.8
Saddle-Aero Bar Pad Drop Moderate: 9.9
Saddle-Aero Bar Pad Drop Intense: 12.1
Saddle-Aero Bar Pad Drop Maximal: 15.8
Pad-Ground Position Minimal: 93.4
Pad-Ground Position Moderate: 88.3
Pad-Ground Position Intense: 86.1
Pad-Ground Position Maximal: 82.4
My issue came with the first result that I got from them is the top tube. That measurement right there says I should be on a 52 or 54 cm bike vs what everyone else is saying. Do any measurements of mine look out of whack. I know that my arms are a bit on the long side but I don’t think that should affect the whole bike that much. Im just really confused right now and am hoping that someone who does fitting can give me a little insight b/c the info coming back from competitive cyclist is really off of what I thought. And if a 52 is really the ideal size for me than I would rather make some mods to my current ride then spring for a whole new bike in the same size just to have a steeper seat angle. Oh yeah here are two pics of me on my 52.
Alrhough the calculator can give a baseline, nothing is going to tell you what bike you really need until you go through the process of a proper fitting, on a size cycle, with a trained and experienced fitter. With the timne and effort you have put in to your analisys of yourself, you could have spent the time and cash to have your answer, and then you would know for sure which bikes would work for you, and possibly your own, with modifications.
I suggest you get fit, but what do I know, I’m just a fitter…
My guess is the calculator was fitting you for a road bike, not a tri bike. the positions are drastically different and just because you ride a 54 road bike it doesn’t mean you’ll ride a 54 tri bike. Saying a bike will fit you based on the size of the seat tube is pretty much a ballpark number. You really need to look at what is known around here as stack and reach. Go to a reputable shop and get fit, it’s really the only way to get all these numbers. An online calculator or asking slowtwitch people for help will really get you no where. This forum likes to tell everyone to get low and forward and bases this on what basically looks cool. Low and forward is great for some people but awful for others, again just go to a good shop and spend a few hours their getting fit. It’s well worth it.
That frame for that position is not too big. On a steeper frame with a comparable head-tube you’ll need a shorter top-tube than the one you have now by 1-3cm.
Not at all - just trying to get a feel for what visual cues you rely upon when evaluating saddle height from static pictures.
(FWIW, one thing I look at is the angle of the shoe-pedal interface. When saddle height is correct, this is generally very close to level, with much if not all of the toe-down angle of the foot being due to the heel lift of the shoe.)
I know what you were getting to. That knee angle would be on the high side of the acceptable if the pedal was in the futhest position from the saddle. Because it’s not, it’s definitely high.
Regarding the visual cues, it’s just a whole visual thing, I look at it and that’s it. I call it the Look Method of fitting.
Agreed.
My wife and I actually sometimes play this game when we’re driving around and spot a cyclist…
My wife always rolls her eyes at me when we pass a cylist. I say “nice bike” or not, then follow up with: “frame too big”, “frame too small”, “seats too high”, “look at that guy bounce when he pedals”, etc. – Good thing I can’t hear what people say when I’m riding
I am not a fitter. As was mentioned, your fit for the type of riding position shown doesn’t look too bad. For your new bike you will need to decide if you want to keep the shallow road seat angle or if you want to go steeper. The religion around ST is to ride steep, but if one can be comfortable, powerful, and pretty aero in a road based fit (i.e the SLAM position and its variations). The FISTers out there will probably say that you are better off riding steep, and they may be right. But I would suggest that you do some test riding of some steep framed bikes before you commit–maybe even see if you can borrow or rent one to try for several rides to see if that works better for you than the current position–maybe even try some brick workouts to see if you run better off of a steep seat angle bike. If not, you may be better staying with what you have and spending your money on an aero helmet and some wheels.
I honestly think most tri bike sizes designated 48 cm would be a bit on the small side for you. Your inseam is quite long compared to your torso, I would definitely look into the QR line, likely a size S in the current lineup.
