Fitters! How do you correct knees hitting elbows in aero? Now w/Pics
Hello there. I’ve been trying to get self fitted on my tri-bike. I feel ok on my current position, the only problem is my knees constantly hitting my elbows. I’ve try adjusting drop, saddle height & set-back, cockpit lenght and nothing really seems to solve the problem. So I come to ST trying to find out some ideas on what to look for and eventually correcting this issue. Thanks all…
If you have a short torso and long femur bones this can be an issue. During parts of his career Lance Armstrong’s knees actually went between his elbow pads on his tme trial bike while pedalling in the aero posture. Karen McKeachie, an elite master triathlete, has also had issues with reach and knee clearance to her elbow pads.
In general you simply have to find an innovative way to move the elbow pad out of the way without compromising the position. Aditionally, you need to be aware that the position may shift forward to a degree in some performance regimes, such as very high efforts.
One thing *not *to do is compromise you saddle position. That is the center of the earth of your ability to pedal well.
The pads may have to be slightly wider, slightly farther forward, slightly higher and/or a different model. Karen McKeachie (she also holds an advanced engineering degree) took a pragmatic approach to the issue and simply cut some of the elbow pad off making it smaller.
If you step back and look at the problem you should have some insights as to how yyou can resolve it.
Best of Luck!
Yes, I’m the guy with the short torso and xtra long legs. 5’11’ 3/4 with a 37 inseam about a 60 cm torso. So separating the elbow pads may be the option ?
*The problem is my knees hitting my elbows, not my knees hitting my elbow “pads”.
I’m not a fitter (I do have a Holiday Inn pen though) but I have to ask, why is this cause for concern?
My knees have touched my elbows ever since I started riding in aerobars and I believe my position is sound.
Do they “hit” in a manner that’s uncomfortable, or unsafe?
I’m shorter than you but have nearly the same leg length/height ratio. I had both problems (knees hit elbow pads when standing on a climb, not when in the aero position). I solved them both by going to a longer stem to lengthen the cockpit. The original stem was 10.5cm and I changed to 12cm.
Suggestion if it bothers you too much: longer stem to push the pads forward, and tilt up the aerobars appropriately to maintain a ~ 90° elbow angle. Call it semi-Landis. Yes, you will open up your shoulder angle a bit, and you might need to put a spacer on your bike to maintain the same hip angle, but you’ll likely be a little bit more compact/aero. It also serves to flatten out your back, for better or worse.
Everyone will then subsequently tell you that you’re riding too stretched out. I cannot, and will not guarantee success.
I have/had the same issue, although my proportions are less extreme than yours, but I basically did just what DH suggested. Upper arms reach slightly forward of straight vertical under my torso, but w/ bars angled up elbows are still at 90. For shorter events (mostly TTs), I keep it slightly stretched out like that (way watered-down ‘superman’); for longer events or when I have to get off and run I add a spacer or 2 to raise the stem up and my knees end up mostly below elbow/pad contact level.
Can you carve a section out of your elbows then?
Styrrell
Can you post pictures in your current position?
It’ll be easier to get to the issue if we know what the issue is. Otherwise, its just random suggestions.
This is a recent photo, the only thing is that here I’m holding the aerobars way in front and I’l like to hold straight onto the extension bend. You can check out a previous post here: http://forum.slowtwitch.com/gforum.cgi?post=2363174;search_string=;#2363174
http://i44.tinypic.com/j5w2eb.jpg
There’s some good advice here already.
One more thing to try is to shorten the crank arm length slightly – this should buy you a few millimeters.
few things:
first, your bike is too small. that is definitely not the right size and possibly not the right brand (nothing wrong with Fuji, you just need a frame with the right stack and reach) for you. I’d research bikes with a tall stack… PM Rappstar for help or post a thread, or search the forum and the front page as well. You look like a roady riding in the drops on a breakaway, not a triathlete.
2nd, despite hitting your elbows, you still look like you have a slack seat angle. I find it much easier to run and also am much more aero when I have a steep seat angle. To do this you’d need to get a longer stem. As you rotate your positon forward around your bottom bracket, you’ll be able to lower your new longer stem maybe and get a better angle for your arms and shoulders as well as possibly get your big noggin out of the wind a bit. you might need to raise your seat a hair when you come forward.
so, to recap, new frame that fits and if not, new longer stem, move forward, lower stem.
Does that bike have a reverse seatpost capability?
With all your respect, That’s all I could afford at the moment. I was working on a low budget and wanted a tri-bike. With the current set up I’m riding about 78.5 seat angle with a 2.5cm setback on the bb, about 15cm of drop. I got the frame one size smaller (54cm) because I was getting WAY TOO stretch out on anything bigger due to my xtra small torso.
How much weight do you have split between your butt and your arms?
I’d try to rotation your pelvis forward, while flattening your back and moving your shoulders more over your elbows.
To faciliate this, you might need to slide even more forward on the saddle and increase your effective Seat tube angle.
I’d say that you’re sitting back with your pelvis fairly vertical to ease pressure on sensitive areas. All this sliding and rotating forward may increase the pressure. You can either learn to the deal with the issues or check out other saddles. I think the Profile tri-stryke is the best bang for the buck.
Take a look through this gallery and you’ll see a more “balanced” distribution between arms and butt.
http://www.slowtwitch.com/photos/Detailed/25.html
I’d liken your position more to Faris and James Bonney, check dan’s comments on them vs the others. Craig Alexander is making a shallow bike work, but also notice his knee vs. elbow position. Looks like some overlap.
What length is your stem? Thats probably the easiest way to add more cockpit length. The thing to watch out for is too much weight on your front wheel and I think you’d have to make an extreme change to hit that point.
Thanks for your input. I’m currently using a 120 stem. I do have a 140 available.
looks like a kids bike to me
Hmmm, actually your fit looks pretty good!
The bike may be a bit small for your size, but as you said, a larger size would present the other problem for your morphology–too long of a top tube. If the handling on your current frame is fine, don’t sweat it.
As I see it, you have two options:
Option 1 (for a more traditional fit): Slightly more forward saddle, slightly longer and lower stem. With is more forward position, you may be able to find a place where your knees miss your elbows.
Option 2 (less traditional): Accept the fact that your knees will be in the region of your elbows for your height. So, what you can do is WIDEN the aerobars and adopt a track-like aero position. Your knees will be inside of your elbows. This isn’t quite as aerodynamic as having your knees behind your elbows, but if it’s more comfortable you may save time in the long run by being able to hold the position for longer. I’d still recommend sliding your saddle forward if you do this, but keep your aerobars in the same position (so you’ll end up less stretched out in the end). The more forward saddle position will probably benefit your run compared to your current setup.
Here’s a good picture of Bradley Wiggins in a position similar to what I’m describing. His shoulders are in a relatively normal position, but his elbows and hands are wide apart, which allows his knees to track inside his elbows:
http://www.telegraph.co.uk/telegraph/multimedia/archive/00784/bradley_wiggins_784770c.jpg
You guys put on some great races up at Purdue. I recommend them to all of the folks down here in Bloomington. Best of luck at Boilerman!
I’d still like to know why you think this is a problem in the first place?
You said yourself “I feel ok on my current position”…
no disrespect intended. I’m just telling you what I see.
That’s why I made the stem comment. If it’s not too long already, you can get a longer one and adjust your position. Also, shorter cranks or aerobars that have a pad that sits more forward than what you have, although Vision pads seem to be right over the basebar so that’s probably the best you can do there.
Again, I hear what you’re saying about getting the smaller frame because the bigger one stretched you out, but a different brand that has more favorable stack and reach numbers might have been better. Once you get ready for a new bike, research that thoroughly before you purchase. Until then longer stem.
good luck.
