Okay, I’ve gone from being a below average swimmer to now an average swimmer. Major progress. But I’ve got some issues that I’m not sure how to deal with or correct. I know getting a video up is best, but right now I don’t have capability. I will soon. Message board description will have to do for now.
SIDE KICK DRILL
To put it bluntly, I suck at this. I’m not really on my ‘side’, but more at an angle. If my lower shoulder should be perpendicular to the MIDDLE of the black line, it really is “pointing” at the inside of the line, so I’m kind of at a 45 degree angle (not that severe). There’s no way I can put my head under water, either to look at the bottom of the pool or the side of the pool for more than 5 seconds MAX. Most of the time, my head is facing the sky, water around my goggles, extended hand out straight, non-extended on my hip, most of the time above the water, or just under the surface. I struggle with this, as my kick seems a bit weak. Any cause for concern? Hope I was able to explain correctly.
REACH
During any ‘regular’ swim set, it looks like my reach is too long, and my arm just kind of sits extended for about a second or so (maybe less?). I’ve tried to ‘speed’ my catch up, but this causes problems as my stroke count would skyrocket. I’m currently at about 19-20 strokes/25 yards, swim golf ~85 or so. A workout partner commented that my reach was too extended, but that was during warm ups, and I think I still do it. Also, when I look at other swimmers under water, it looks like their catch is much more active than mine looks to me. But I could be wrong. And, the kicker…the more I make an effort to roll on my side, the worse…or longer…the reach seems to get.
I’m trying to copy Grant Hackett’s form (I can’t, but I try) that’s linked to video in this article Dan posted a while back:
http://www.slowtwitch.com/Training/Swimming/Has_swimming_got_you_over_a_barrel__238.html
To these untrained eyes, it doesn’t LOOK like his reach is that long. But I know I’m not looking for the right things.
Normal or not?
Thanks for any help. I’ll do my best throughout the day to post any follow up answers…or questions…as regularly as I can.
MJP
When you say “long” reach, do you mean long in duration?
Yes, it feels long in duration, like my arm stays straight for a bit too long. I also might be reaching too long (distance wise). At least that is how it feels.
how far back are you pulling before starting recovery?
I was having an issue similar to this, but it turned out that I was trying to extend my pull too far (past my hip), which was delaying my recovery.
The only way you can reach too far forward is if it’s causing you to go serpentine through the water. Getting that last little bit of reach (distance wise) is good.
Depending on the pace you are swimming, you may be right to be gliding. Only when you are an elite conditioned swimmer can you swim distance races with a full stroke and quick tempo.
When doing the side swimming drill your top shoulder should be rotated past 90 degrees. If you were perfectly vertical, the weight of the shoulder/arm would sink you and your head would go under. You need to rotate past 90 so that if you were on your left side, with right shoulder high, that shoulder would be past vertical and your right pectoral would start to be exposed above water.
It sounds like you are trying to keep the shoulder out of the water, or rotating just less than 90 degrees…how would you breath!!!
SIDE KICK DRILL
Don’t worry about sucking at this drill. It just takes time and effort to get it right. I personally think this is one of the better drills to improve swim kick and also helps a bit with body rotation when you get more advanced. I have a few thoughts that may help you out.
- Start using fins and focus solely on keeping one shoulder “dry” and out of the water. Fins will help tremendously with keeping you on your side until you become more comfortable. I usually keep one goggle in the water and one out and I find that breathing is not an issue.
1a) Now take the fins off and see how it goes. You can also mix in a body rotation drill, kinda like an extended catch-up drill. Kick on one side for 6-10 kicks, then rotate over to the other side for 6-10 kicks and repeat.
- After you are super comfortable with that, put the fins back on and this time put both arms at your side, point your shoulder at the black line, and tuck your chin into your shoulder so that you are looking face down. The fins will help you maintain speed and will allow you to rotate your head towards the surface to catch a quick breath every 6-10 kicks.
2a) Now try that without fins. It f-ing sucks.
Enjoy ![]()
oooh, that progression is new to me. I can do 1 and 1a flawlessly, onto 2 tomorrow!
Your problems with kicking on your side are possibly related to poor core strength. Plus I would say it’s not a big deal to get exactly on your side. As others have said, it will take a while to get better at this but I suggest that kicking on your back is a better kicking drill. For one thing, it will show your right away if you are bending your knees too much (a common mistake) because they will break the surface. Will also show you if you are letting your butt sink - again, a core strength issue.
On the reach problem, 19-20 strokes/25yd is not terrible but if you are extending a lot and you STILL are taking 19-20 strokes that tells me your pull and or your kick is weak. From your first point I’ll assume your kick is not doing you any favors. That said, how much force do you put into your pull? Simply gliding prior to your catch is never going to make you faster, even if it does reduce your stroke count. I like that you play swim “golf”, if you aren’t already, try a set of 4x50 where your “score” gets better on each one. Will force you to maximize your pull.
P.S. Don’t worry about what Grant Hackett does.
What’s serpentine through the water mean?
And side kick…I am rotated past 90. How you’re describing it is how I’m on the water, you described it better than I did.
SIDE KICK DRILL
Enjoy ![]()
My shoulder is dry without fins, even though my description may not have sounded that way.
I have no desire to try 2 + 2a. They sound like torture…
serpentine = snaking through the water = horizontal movement rather than straight forward.
as to your other comment, the torture is good for you. Like swallowing vitamin pills.
I did the back kick drill, but the same person who said my reach is too ‘reachy’ also thinks that the side kick drill is better than back kick. And since she swam in college for a year, I’m trusting her. (I really haven’t followed up asking her some things, but plan to at some point)
My kick is probably weak, yes. I never focus on it honestly. My thought process has been to kick less, save them for the bike + run.
I put a lot of force into the pull, at least a lot to me. But when I play swim golf, the less strokes (for me) = more gliding, which is what I’m trying to avoid. Does that make sense?
Not to get into a pissing contest with the girl who swam in college for a year but I swam four years at the University of Tennessee along side several Olympians and world record holders so listen to me!! ![]()
Kicking on your side, as a drill, has merit. There is a video on Flo Swimming showing the Auburn sprinters (boo!) doing side kicking focusing on not using their arm for position correcting. I’m too lazy to look it up but the point of the drill is to focus on core for stability. Not entirely sure why else she’d advise kicking on your side as most swimmers kick on their back or with a board. Again, the important part of side kicking isn’t for you to be precisely on your side. If you’re relatively new to swimming, it may take a while (years even) to get fully knowledgeable about/master how your body is positioned in the water.
I agree with not focusing heavily on kicking for tris but having a “good” kick **is **important.
About the swim golf. I don’t think you’re doing it right, at least not from your comment about more gliding. The key is to reduce the stroke count AND get faster on each 50. Try it with a pull-bouy which will stop you from just kicking harder to go faster.
Well, I’m an FSU guy, so we’ve got a true disdain for the gators in common. So, I have no problems listening to you!
I’ll check that video out, and do my best to get some video of me up.
Please beat teabags…
