First Tubulars, now which tire? Zipp, Vittoria Tri, TUFO or other suggestions?
I just switched to the Cont Competitions before Steelhead. They had a nice feel. I have heard they have good puncture protection as well. I only have about 100 miles on them, though. Prior to that I was using Tufo S3 lites. I never had flats with them, either, but I think the Contis have a nicer feel.
I had only used tufos prior to my Conti Competitions. I don’t think they are slow. I think that has been exaggerated. I rode the S3 Lites and HiCCs.
Another vote for the Vittoria EVO Corsa CX
Well, after all of the time I spent looking things over, I ended up going for the tire I originally had in mind when I started this search, the Vittroia Corsa Evo CX. Not necessarily a TT tire but one of the best all around racing tires. Once I get myself down to a lower weight and a more competitive status, I’ll consider going with the Vittoria Crono CS and its unbelieveable 100g weight savings over the EVO CX. The wheels, tires, b/s can of mastik 1, valve extensions, carbon brake pads should all arrive on wednesday, which coincidentally is the first day of a much needed vacation. Thanks for the help everyone, I’m sure I’ll see many of you at races in the future. Just look for the guy on the Seduza with Neuvations as you pass ;). Did any of you do Wilkes-Barre?
Good choice(s) and good luck! Now put the equipment mess out of your mind and ride lots!
Thanks rroof! The cronos look good. The question is at 170g would they be flat prone for a 170-175lb dude? I know when it comes to tires much of it is just plain luck and some has to do with just how you ride. I had really good luck with the pro race2 clinchers and hope to find a tubular that is just as good (of course I understand the ride will be much nicer). I can’t wait!!!
The Vittoria Cronos are stupid-fast. Unfortunately, in my limited experience, their puncture resistance sucks. The Triathlon EVO and Corsa EVO are both excellent choices. The Triathlons are a bit lighter, but have that damned butyl tube.
Finally got the tires mounted correctly and made it out for the first ride. It was short but sweet and the wheels run smooth. Tonight I’ll be testing things out on my TT course (if I can fix my shifting woes).
p.s. my first gluing attempt was a disaster, glue everywhere. There was also the little misfortune of the gaps around the valvestems…evidently the tires were defective.
I’m hoping the Vittoria will make good and replace them as I purchased another set which glued perfectly with no gaps and this time my glue job was much much better.
Looking forward to Lake George this weekend!!!
