Finis Forearm Fulcrum
Hey ST swim gurus. Has anyone used this training tool from Finis? Does it work?
http://i16.tinypic.com/47ik8au.jpg
Product Details
The Finis Forearm Fulcrum holds the hand, wrist and elbow to position the forearm optimally. The Forearm Fulcrum is comprised of two closed sections. The process of placing the hand through the two sections creates an ideal elbow-wrist angle. This positioning of the forearm creates the most efficient application of propulsive force. The Forearm Fulcrum can be used by swimmers of all levels to improve stroke technique and has applications for all four competitive strokes
Yep. once you work out which way to put them on.
Clever… very clever. Assuming you have the problem that these things solve!
SteveMc
Is it supposed to be placed at your elbow and wrist or above your elbow and down to your forearm so that you keep the arm angle correct? I guess i’m confused on how it works.
Thanks,
E
Well I put them on the wrong way initially and it didn’t feel too bad so there’s no obvious indication. Basically, you put your hand up through the first hole and then down into the second so it forces you to keep your wrist level with your elbow, in order to keep them from moving about. So they’re good for people like me who drop their wrist on entry, lowering their hand too quickly and thus not getting sufficient catch. Perfect for warm up and cool down.
I hope that helps,
SteveMc
p.s. the finis freestroke paddle is excellent too, forces a nice long catch. Not so sure about the snorkel, kind of annoying
You can pick up your Finis Forearm Fulcrum and other fine Finis products at www.swimyourbest.com. Enter the coupon code, “openwater” for 20% off your order at checkout.
Works great. Wish I had thought of it!
