Fiesta Island TT Course
Are there any turns on the course which require coasting or speed scrubbing/reduction? My impression is it is full gas for 20K, but sometimes slight curves seem to scrub some speed. Going to be at the 10/11 TT, should be fun!
No scrubbing turns, just significant headwinds in particular sections.
If this is actually on fiesta island, then there is 1 turn that will really need to be braked for.
It is the left hand turn with the hump right outside of the dog park, you can really lose a great deal of traction there going full speed.
There are no turns that require coasting or speed scrubbing as long as it’s dry, there is no sand on the course, and you take a good line.
No corners that need to be taken at anything less than full out, unless you are averaging more than 35 through them. If you are having trouble with the corners then you might need to adjust your line through them. IIRC, Olin did his fastest time at Fiesta in the rain on a fixed gear with an average speed of 28+mph.
So long as there is no sand out there, you should be fine going all out the whole time.
