I’ve never heard of grass mulching killing dandelions. Plus, I believe turf builder is more fertilizer than weed killer. The bag that is a Spring specific says it “Thickens lawns to help crowd out weeds.”
why do people feed the lawn?. the last thing i want is the grass to grow faster; all it does is create more work mowing it. Don’t fall into the trap unless you want to give up your weekends. use one of those spray things that kills the weeds but not the grass, and stay away from anything else
95% of the time in a “weed and feed” mix, you get a pre-emergent herbicide and a fertilizer usually in a ratio of 3:1:2 or 4:1:2 (nitrogen, phosphorus, potassium).
Pre-emergent herbicides will not kill weeds that you can see. If you can see the weed, it is post-emergent meaning you need a post-emergent herbicide such as 24D or similar herbicide if you are selectively killing weeds.
There are some granular mixes that have post-emergent herbicide in them. Scott’s may even sell one. However, typically post-emergent herbicide will be in liquid form.
For the strength of the herbicides that you can buy at your local home store, throw it on the lawn, then come back and put some post-emergent on.
Do you know how often I need to mow my f$&@#ing dandelion field? Those things grow several inches a day, are unsightly, and annoy the neighbors. Way less maintenance to mow and fertilize the lawn.
I think my yard is beyond repair at this point. I’ve got to go scorched Earth with a bobcat and start fresh.
