I Use Qbicles
https://www.torpedo7.com.au/products/QBMURNNQ2/title/qbicle-road-bike-rear-fender
They work pretty well and are low profile, a bit fiddly to set up initially.
I Use Qbicles
It’s not enough that it’s dark at 5 now? I’m not ready for winter pictures yet!
best hit the cyclocross pitch then
Or the trainer in the comfy confines of my basement.
Make sure you have a cheery and inviting environment. Use mine as a model:
and I thought this was a thread about playing guitar while riding a bike…
Not sure if anyone has mentioned this yet but I use a fender from Asssavers.com. They’re super low profile and easy to put on/remove while really getting the job done. Really sleek, too, while being cheap!
okay, but still nowhere near as effective as full guards, if you’re riding on your own but useless in a group… you won’t be popular with your rides mates on a wet day
yes, the water was coming around the side of the fenders and getting my feet wet on the downhill so i added the milk jug. Fenders should come with those from the factory. note on the back one i added an extra mudflap made of wall cove to keep my chums dry in the shit. and it worked
I’ll take this over the trainer any day… unless you can just go skiing instead.
Rollers, a power meter, a replay of a good edition of a spring classic, and a SST workout 100 times over before I ever do that.
Can you provide a little more insight on how you put the longs on with P-Clips? I have all the parts on hand, just struggling a bit on how to make the connection.
Hi Jesse,
Unfortunately I don´t have that bike on hand at the moment, it´s currently in Basel and I am in Frankfurt, so no pictures.
But what you do is attach the guards to p clips on the seat stays rather than running the mounts through the QR skewers.
The owner of the bike below has done something similar front and back.
http://i.imgur.com/0YY8tWs.jpg
Any questions, fire away.
I use the CrudCatcher Road Racer MkII fenders. IMHO, much better than the Raceblades because they have a a lot more coverage. They cover the drivetrain with an extra bit near the front derailleur. They are much longer than the Raceblades. In the front, they cover in front of the brake, catching the spray that comes up and back into your face at speed. They also keep your shoes drier. On the back, you can put on a short tail for most days or a long tail that will mostly protect the rider behind you. I never bother as they are running short fenders, so if I am going to eat their spray, they can eat mine.
The downside is a more complicated install process, but not by much once you have done it a couple of times. I skip the reusable zip ties on the brake bolts and just cut them to remove them. I leave the frame mounts on all winter, as they are small. You will get a tiny amount of extra draf from the brushes that hold the fender away from the rim, but it is Winter–you need the extra work.
