Felt Serial Numbers
How can I find the serial number on my Felt? There are three labels under the bottom bracket, each with a different set of numbers. Which one is the SN? Thanks!
Reviving a dead topic because I have the exact same question. Three different labels under the bottom bracket, two of which have 2 numbers each.
Which one of these is actually the serial number?
SuperDave should chim in pretty soon, but it should be a number with the following format:
1 Letter- 3 Numbers - 1 Letter - 4 Numbers.
At least that is what is on my wifes Z2, and the web site took it as the serial number.
Hmm, nothing quite like that on mine, but I should have mentioned the model and I appreciate the response.
On the 3 labels have, the format is like this:
FEFM##-B12-56
AK#######
BI-####
WUD###
#####D
The first number on the first label is about the only one I’ve been able to make sense of, the last half of it at least indicating that I have a 56cm B12.
According to this web site:
http://frameandwheelservices.blogspot.com/2010/09/2008-felt-b12.html
It is the AK number on the first sticker.
Which frame do you have?
