Brakes should be moved away from the bottom bracket and put back on the seat tube like the Venge
x2… it is just a PITA to work with those brake and if something goes wrong on race day then u are pretty much fucked
On my local group ride, the rider in front of me had a rear brake on the bottom bracket. It was interesting to watch how close the wheel came to the brake pads as the wheel flexed a bit. It just seems like a terrible place for a brake. Chris Yu at Specialized mentioned the airflow accelerates under the bottom bracket and a bottom bracket brake may not be as aero as people once thought. Not only that, with their wheel flex measurements, they pretty much confirmed that it’s a terrible place for a brake.
Industry designers reading this thread…please move the brakes
don’t get me going with my shiv bottom bracket brake… PITA x100000000000000
Under the BB brake on the Speed Concept 9 (2012 model in my case) seems to work great, but there is a pretty big cover that fits over it to protect it… ![]()
Never once had an issue with the P5 rear either.
I don’t think under the BB is the issue. I think the brake itself tends to be. Like, put a DA direct mount down there and I’m sure it’d be fine.
Are there any other brakes you can think of that anyone has found that might fit?
The new Bontragers? Tektros? Or a tri rig omega x? anything that isn’t based on a roller design?
For folks who tried the shimano direct mounts, what was the compatibility issue? just width?
Nothing will fit without modification or adapter. The frame is threaded so the brake must be installed with a bolt, not a nut as a traditional caliper. The frame does not use two mounting bosses (tektro U brake) or threaded inserts (Shimano direct mount) so these brakes will not fit.
The new Bontragers? No
Tektros? No
Or a tri rig omega x? No
anything that isn’t based on a roller design? Nothing that mounts with a conventional brake nut, mini linear pull studs or shimano direct mount.
The mounting standard itself and of course the brake cover (and potential interference with powermeters
Thanks for the quick response as always dave. I appreciate it.
Hey Dave, the Omega X **does **install with a bolt, and it can go straight into a threaded insert on a frame. This is how Dimond’s rear brakes work, and they’ve been using the Omega Standard and now the new Omega X. Have a look at the installation guide at http://www.tririg.com/omega – as far as I can see, it should be a good candidate to work on the rear of the IA, sans cover.
Edit: maybe this image is enough to show you that it will work:
Forgive me for the naivety but isn’t this a race bike meant to be ridden in races? I get that it’s expensive and we all want to use our fancy toys more frequently BUT standard practice is you race and train indoors on your race bike with limited outdoor exposure. You then have a secondary bike to take out into the harsh elements to get in outdoor training rides.
I get the economics of this is absurd but you don’t drive a Ferrari to Costco for a grocery run. That all being said I do empathize with your troubles and frustration. For what it’s worth I’ve replaced my cable housing with Yokozuna Reaction Compressionless Brake Cable Kit and I’ve had zero issues. Perhaps looking into better housing could solve the issue?
Thanks for your suggestion. Along with clearance, the cable routing and height could be problematic.
I won’t say impossible but you’ll need to forgive me erring on the side of caution from a legal standpoint at the least and from a lack of ISO testing, etc conservatively.
-SD
Yes. Would be interested to see if this would work. If so, buying.
Completely understand. Just for clarification, the Omega is indeed safety certified under EN and CPSC.
To original poster,
my IA4 has basically the same problem.
After an e-mail to SDave I received a stronger spring to solve the issue.
On top of changing brake housing and cabling to high quality parts and installing the new stronger spring I disassembled and cleaned the brake.
Unfortunately this has not solved the issues.
While rear brake (still old spring) seems to now work most of the time (new housing+cabling), the front brake now locks up/seizes up in braking position, despite the stronger spring.
It happened to me twice during IM Frankfurt last week (will not blame my poor result on that) and really didn’t care for it happening in race situation as I had to reach down to ‘release’ the brake manually.
To me, these brakes are not fully functional in the real world. Yes it rains sometimes, yes there is dirt on the roads and Felt needs to do modifications to guarantee full function of brakes.
Love the bike, love it’s handling, have a great position dialed it in, but Felt should deliver a proper fix beyond advice on cabling/housing etc. Just not enough.
After owning this bike for a year now and having 5000 miles on it and going through two lock up rear wheel periods I know to pull regular PM on it. If I get caught in the rain like I did yesterday besides cleaning the bike and chain I pull the rear wheel take my compressior blow the rear brake clean. It is amazing how much junk comes out. I also own a specialize S works shiv with 12000 miles on it, not one problem with the rear brake which also under the rear stays. But to be fair on this the felt brake is stronger in stopping power.
Hi all,
i had the same problems with the rear brake of my Felt IA FRD. Now i have installed a TriRig Omega X Brake - it works perfect. With little modifications i can use the cover. I recommend this solution for the rear brake issue.
Rear brake on both the Felts I have owned were and are the worst thing about the bike. I had a DA3 and now an IA2.
If this is a solution then wonderful, you may have just saved me countless hours of cursing, high blood pressure spikes and removed the fear my children have when dad is
working on the rear brake days before a race!!!
What little modifications?
Can you post pictures with and without the cover on?
