Felt DA Stack & Reach
Dan’s various articles mention these stats, and yet I can’t find them. I’m looking for the stack and reach for the 56cm Felt DA, so I can compare them to a P2C…
Thanks.
I haven’t seen these dimensions on the DA either but I believe Dave Koesel (aka Superdave no this forum) does have those statistics. You can PM him on this forum.
More importantly, thanks for a killer ride in Curacao. Good way to start the year.
I’ve been looking into this myself actually - the bike geometry page is here:
http://feltracing.com/products/product.asp?catid=18,20,51&pid=21
(click on “Geometry” just below the picture)
Although I’ve actually been making my comparisons based on top tube length and head tube height. I figure these are accurate enough proxies for stack and reach. Felt and Cervelo are kind enough to list “effective” top tube lengths for both the forward and aft saddle positions. What I did because I can’t keep more than 3 or 4 numbers in my head at one time is put the dimensions into a spreadsheet for each configuration and size of each frame I’m looking at. Then it is at least possible to see everything at once.
I can pm you the spreadsheet, actually, if you want.
you’ll find it here.
Pleasure was mine, Tom. I don’t think we got a chance to say goodbye on Saturday night (we had the early Sunday flight). It’s the people that make that trip special, and you & Sarah certainly were part of that.
Gorgeous.
So by my read, the P2C 56cm (531 stack, 429 reach) is a wee bit taller and longer than the DA 56cm (525 stack, 425 reach).
I currently ride a Soloist 56cm (560 stack, 394 reach) configured about as low as an aerobar can go (PD integrated, 10cm stem). If I understand this stuff correctly, I pretty much aint gonna fit on either one of the above. I’d need like a 7 or 8cm stem, and 4cm of spacers/rising stem, if I use the same aerobar!
I got a different scenario, I see a 110 mm stem with 12 degrees of rise. From there, the aerobar selection and pad height adjustment should get you on a DA. With the P2c you’d need a shorter stem w/ less effective rise.
What aerobars are you using?
Really? Maybe the math isn’t as straightforward as I thought!
Soloist = 560 stack, DA = 525 stack. All else equal, wouldn’t I need 35mm more spacers/stem rise? And then Soloist = 394 reach, DA = 425. Again, all else equal, I’d expect I would need 31mm less in the stem, thus 100-31=~7cm stem?
I have been using the PD Carbon X aerobar, 100mm stem, no spacers, pads mounted to the base bar, extensions mounted under the bar. I want to use the Zipp Vuka bar. And since I like the base bar reasonably low on a tri bike (unlike the herds on their mtb-like positions), I’d want to fit the arm rests to the right position with 1cm of spacers under them, and have the base bar lower that it would otherwise be.
7cm is the horizontal component. You’ll need to take into consideration that the stem will have to have an upward rise.
True, but isn’t that a really small difference? A 110mm stem isn’t going to become a 70mm stem from a 12* rise. Am I missing something?
35mm of spacers do not give 35mm of rise - they give you 35 x sin(HTA) of rise - this makes a difference
It works out much closer on the stem reach though.
Tell me what size the current frame is and spacer stack and I’ll do you a comparison chart
Cool. Current is 560 stack on a 56cm Soloist, with no spacers below the stem (and the stem is flat).
are the two smaller sizes of the P2C and P3C really identical?
http://tinypic.com/view/?pic=4bdyufn
Slowmans stack and reach figures come out a little different to mine, I haven’t worked out why yet and am unwilling to change my method until I work out where the discrepancy arises. So I have put both sets of figures in.
The clamp height on the carbon-x is to aloow for the way my formulae work - I have measured up those bars.
The saddle height is just to show a constant height for a given angle so that the drop can be calculated.
If you wanted to go to one of those bikes you would have to consider shifting forward and down.
“Slowmans stack and reach figures come out a little different to mine, I haven’t worked out why yet”
the stack and reach measures i publish consider the horizontal and vertical distance between the bottom bracket and the head tube top. are you measuring from BB to a different point?
Hey Dan
Since you are sort of on the subject of the DA, do you have any plans for a review of the new DA/B2 frame?
I’m just getting back around to this, so sorry to have taken so long to say thanks for that work. Thanks!
If I’m reading your chart right, I’m not even CLOSE to fitting a P2C or DA. The 56 DA, for example, would require a 7cm stub of a stem and 5.5cm of spacers AND a 7 degree upsloping stem!?
Superdave had thought I’d be using an 11cm stem, sloping up 12 degrees. Big difference there.
I don’t get it – I ride with a decent drop, ~13cm, which is more than average, yet I don’t fit anything on paper.
Perhaps if you used a carbon X on the DA.
Where is your local Cervelo/Felt dealer? I’m dangerously close to solving this riddle by heading to the local dealer and setting up these bikes w/ your measurements if for nothing more than personal validation of my measurements and curiousity. Do you see that the relative length of the stem in the photo is accurately 100mm from the center of the fork steerer to the center of the base bar?
http://www.profile-design.com/recall_images/carbonx.jpg
http://www.jackandadams.com/Images/Product/Felt_S22_sm.jpg
Now look at the Vuka set up with the stem clamp position much further forward on the base bar as well as the extentions themselves being shorter and with integrated brake levels. I say again you’ll need a longer stem to achieve the same hand position:
http://www.all3sports.com/images/images_med/ZP6VKAB.jpg
http://www.forum.slowtwitch.com/gforum.cgi?do=post_view_flat;post=1010798;page=1;mh=-1;;sb=post_latest_reply;so=ASC
Ah ha, with a 100mm stem installed, the center of the fork steerer tube clamp to the end of the Zipp Vuka base bar’s integrated brake lever is 42mm SHORTER than a Carbon X’s w/ their labelled 100mm stem to the end of the cowhorn/basebar’s installed tektro brake lever.
-SD
Note that using high stack aerobars would reduce the spacer stack beneath the bars.
To use one of those bikes you would need to either bend a lot more or shift forward a lot.
Maybe you already have exactly the right bike and don’t need to look at anything else (the bike buying gods will strike me down)
